UK light switches, wirelessly working with ML Gateway?
This post has 7 Replies | 0 Followers
frog
Camberley UK
Posts 624
frog Posted: Fri, Mar 30 2012 4:26 PM
I've just got a ML Gateway and it works great with the iPad app, but I now want to expand its use into other things like light switches. As my house is already constructed, I don't want to have to channel low-voltage wires to each switch, but to use a wireless system. Does anyone have any recommendation for a UK (60 x 60 light switch fitting) that I can use to start building out my own system?
RussR
Posts 63
RussR replied on Fri, Mar 30 2012 7:46 PM
try here
http://europe.lutron.com/default.aspx?cntid=1
We kid because we love.
frog
Camberley UK
Posts 624
frog replied on Sat, Mar 31 2012 6:59 PM
Yes, I've looked there. The RA and RA2 are US only so there aren't any wireless solutions for the UK from Lutron.
Has anyone had any experience with a wireless solution with the ML Gateway?
MartinW
Posts 389
MartinW replied on Sat, Mar 31 2012 8:13 PM
We use Lutron Grafik Eye QS with the NWK Ethernet adaptor - works perfectly with Gateway and the app, blinds too
frog
Camberley UK
Posts 624
frog replied on Sat, Mar 31 2012 9:23 PM
That's good, but doesn't support wireless UK sized light switches. Nice idea about the blinds though. After 3 years, I hope the battery is easy to replace.
frog
Camberley UK
Posts 624
frog
Camberley UK
Posts 624
frog
Camberley UK
Posts 624
Page 1 of 1 (8 items) | RSS
