Soundsmith cartridge
This post has 10 Replies | 1 Follower
MoglesMac
Posts 4
MoglesMac Posted: Wed, Jun 26 2013 11:02 PM
First of all I want to thank all at this forum for the excellent help I have had in the past,
I have since 3-4 years back a SMMC4 which now started to sound abit "flat" and "dull". First of I discovered that it was collecting alot of dust which first make the sound to be muffled, now when I have cleaned the pickup multiple times it gathers alot of dust fast and even when I have cleaned it it still sounds off.
I have used the pickup rather alot and played some "bad" records, so I have been rather brute with the pickup, is it correct of me to start saving for a new pickup? Is a bad pickup more prone to pick up dust? It still plays but it sounds "flat".
Thanks in advance for input
Jesper L
Sweden
MediaBobNY
Greenwich Village, NYC
Posts 1,106
MediaBobNY replied on Thu, Jun 27 2013 12:33 AM
It could be gunk (as opposed to dust) coating the stylus.  Take a cotton bud (Q-Tip), dampen it in isopropyl (rubbing) alcohol, and *very* gently brush the stylus from the back of the cartridge toward the front (not the other way).   And clean your records using a Discwasher or similar brush.  If you had a stylus magnifier you could check the condition of the needle but I'd guess it's still okay.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Jun 27 2013 5:54 AM
A cartridge with recessed treble often means a worn out stylus.
You could therefore return it to its manufacturer to have it re-tipped, or send it to Schallplattennedel in Germany!
Jacques
Millemissen
Flensborg, Denmark
Posts 14,680
Schallplattennadeln.de - yes, Axel is the man Yes - thumbs up
MoglesMac
Posts 4
MoglesMac replied on Thu, Jun 27 2013 10:14 PM
Thanks all for the input, I will try the isopropyl cleaning first and then maybe send a old MMC2 for retipping since I have heard alot of good about them
Jesper
Sweden
Søren Mexico
Mexico City
Posts 6,411
Pickup cleaner I use this one, used since 2 years on SMMC4, no problems
MediaBobNY
Posts 1,106
If you could ballpark the number of play hours on the stylus, that would be an indicator of potential wear.
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Jun 28 2013 9:44 AM
Søren Mexico:
Too expensive for my tasteBig Smile
//Bo.
A long list...
MoglesMac
Posts 4
MoglesMac replied on Sat, Jun 29 2013 10:43 PM
I have now used some isopropyl and I think the sound is abit better now, clearer and the stylus dont gather as much dirt and dust now.
The playhours for this stylus is around 200-250 hours during the 3-4 years but that is a very rough estimate.
Will however continue use this one a while more...
Cheers
Jesper L
Sweden
Steffen
Denmark
Posts 1,408
Steffen replied on Sat, Jun 29 2013 11:26 PM
The stylus should not be worn after only 3-4 years and a few hundred hours of use.
I have a MMC2 and a MMC4 which I have had from new. They are more than 20 years old and still sounds fine. (They have not been 'heavily' used -but used regularly).
Over the years I have bought some turntables with worn or broken styluses -so it's not only a matter of age.
But they should definitely last longer than 3-4 years...
MoglesMac
Posts 4
MoglesMac replied on Sun, Jun 30 2013 5:09 PM
Thanks too all the input here and yes I think I was easily spooked over ageing stylus :) after cleaning the stylus sound is much better and the particular record I used was prob very grimy eventho it looked very nice in daylight with no scratches.
One happy stylusowner :D
Jesper L
Page 1 of 1 (11 items) | RSS
