I need to extract audio from masterlink to a 3,5” minijack TRS (Tip Ring Sleeve)
Should I connect it like this?
Masterlink >> minijack
White/Orange -L >> Sleeve
Orange +L >> Tip
White/Red -R >> Sleeve
Red +R >> Ring
Masterlink audio is distributed in a BALANCED audio format, so ideally you should insert a 1:1 ratio audio transformer in each channel, then you can UNBALANCE the audio to go into your minijack.
Ron
DoubleU:I need to extract audio from masterlink to a 3,5” minijack TRS (Tip Ring Sleeve) Should I connect it like this? Masterlink >> minijack White/Orange -L >> Sleeve Orange L >> Tip White/Red -R >> Sleeve Red R >> Ring
Oke, first I'll try without the BL-Active, solder a minijack straight to the ML, and go from there. If there is too much noise in the rest of the existing ML-wiring I will add the active kit.
Thanks for both answers!
