Upgrade beomaster 5 harddisk
This post has 210 Replies | 11 Followers
andy_js
Englandshire
Posts 223
andy_js replied on Thu, Jan 19 2017 10:52 PM
This may not be good for the components.  Static (from the carpet) can damage them.
Kiran
UK
Posts 1,023
Kiran replied on Fri, Jan 20 2017 6:35 AM
The SSD is back inside the BM5.
It's running lightning quick.
I wish I could take a video. When I scroll the wheel, it's like it goes on for infinity in my track list. I have around 10K tracks on a NAS.
I hope it stays like this. It's so fast and fluid. There no jerks. It's now had its MOT 😂😂
I think I did it!!! 😝😝😝
My previous posts contain exact steps I took 👍🏻👍🏻
Regards
Kiran
Born in NL; I ride ML
nico vercammen
Elversele, Belgium
Posts 174
that's good news !
Hope you do not have problems booting from it ..
The system boots after a couple of days automatically (the only way to get XP stable i guess ...)
I tried (as several other people did also)  sometime ago with the  samsung SSD. copying the disk was no problem but booting was a problem... It booted not always because the motherboard does not support it 100 %  ...
When it booted from the SSD  it was indeed fast. but because the BM5 boot automatically after a couple of days it is not usable ...
I use now a hybrid disk and the result is also good but not as fast as 100 % SSD ;-)
Keep us informed if there are no problem booting the system every time
nico
Kiran
UK
Posts 1,023
Kiran replied on Fri, Jan 20 2017 5:05 PM
nico vercammen:
that's good news ! Hope you do not have problems booting from it .. The system boots after a couple of days automatically (the only way to get XP stable i guess ...)
I tried (as several other people did also) sometime ago with the samsung SSD. copying the disk was no problem but booting was a problem... It booted not always because the motherboard does not support it 100 % ... When it booted from the SSD it was indeed fast. but because the BM5 boot automatically after a couple of days it is not usable ... I use now a hybrid disk and the result is also good but not as fast as 100 % SSD ;-)
nico
Mine booted 1st try and hasn't rebooted since.
I was also playing music from my nas straight away just after selecting the nas as a music source. Normally it would take ages gathering all the music from the nas and it wouldn't even play until it's read all the tracks.
Hopefully it stays this way 👍🏻👍🏻
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Fri, Jan 20 2017 5:30 PM
Okay I'm having one problem which I was having before with the old hard drive too.
When the music source is NAS, it keeps rebooting as soon as I press N.Music.
I have changed it back to internal hard drive and now working perfect lightning quick again.
I don't have twonky running. Could this be it?
I don't think my Seagate NAS can do Twonky?
Regards
Kiran
wantoniak
Posts 26
wantoniak replied on Tue, Jan 24 2017 6:23 AM
Did you replace with SSD?
Kiran
UK
Posts 1,023
Kiran replied on Tue, Jan 24 2017 6:28 AM
Yes everything works fine except selecting music from NAS
My NAS isn't running Twonky so this maybe why it cuts out?
Regards
Kiran
Alejandro Blanco
Buenos Aires. Argentina
Posts 1
I have a Beomaster 5 with hard drive brake.
I need install the windows xp and original Bang & Olufsen Soft.
Haw can i make this. ?
frog
Camberley UK
Posts 624
frog replied on Fri, Jul 27 2018 7:11 PM
Short answer is - you can't...  Firstly - are you sure it is the HDD? Quite often it is the motherboard.
Try pulling out the disk and seeing if you can access all the partitions on the disk - if you can, then the likely problem is the MB. This can be replaced by either a B&O one or a MB which is mostly compatible - you just need to do a bit of surgery on it (there is a good thread in this forum that explains how to do it.
Damir Grgic
Dubai, UAE
Posts 21
Hi Martin
I know it's an old post, but I just recently bought a 1TB BS5/BM5 and so far I have successfully upgraded it with WD Blue SSD.
My initial intention was to expand available storage to 2TB, but I only managed to use it up to 1TB. When I do re-partitioning with MiniTool Partition Wizard, BM5 boots up normally, but when I select Mode->System on main navigation screen (to check available space), system crashes instantly. For the same reason I cannot enter the Service Menu to reboot it from Service Tool USB and do the Recovery... :-/
I've seen from your posts that you uses Gparted. I used MiniTool PW (doing it on another PC), as IMO all disk partition tools should be doing the job more-less the same way. Are there some additional steps/parameter settings which I am missing?
I am using BV7-40 as a monitor, have Service Tool USB and keyboard/mouse combo. I haven't transferred any music yet, so doing everything from scratch.
All suggestions are welcome
Thank you
Damir
fangio
Posts 4
fangio replied on Wed, Feb 2 2022 11:46 AM
Hello Damir
which WD Blue harddisk do you have installed ?
It works fine ?
Greetings
Stefan
Page 6 of 6 (211 items) « First ... < Previous 2 3 4 5 6 | RSS
