Beomaster 1200 Gramophone input? Warning! stupid question inside!
This post has 7 Replies | 0 Followers
Laban666
Sweden
Posts 15
Laban666 Posted: Mon, Jul 1 2013 11:52 PM
This might be a VERY stupid question, but anyway....
I read in the Service manual that the Gramophone input is:
Low inpedance: 4mV - 1000Hz / 47 kohms
High impedance: 200mV - 1000HZ / 470 kohms.
And the Tape recorder input is:
200mV - 1000HZ / 470kohms.
So, if I switch the gramophone input to high impedance, will the gramophone and tape input be exactly the same?? So I can connect a CD or a tape-player to the gramophone input?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
The gramophone input has a compensating RIAA preamplifier that allows for the non-linear output from vinyl records.
This input will not work for tape or CD players which have linear outputs.
Graham
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Jul 2 2013 9:39 AM
Actually not so sure about this. The switch was originally designed for crystal pick ups which had a relatively flat output as they work on amplitude rather than velocity. To be fair, the frequency response is nothing like flat in Hi-Fi terms but it pre-dates  this! The high output should therefore switch away from the RIAA - my electronics ability is next to nothing but that would appear to be shown in the circuit diagram.
So the input could be used with a CD player.
I think! Big Smile
Peter
tournedos
Finland
Posts 7,357
The levels are compatible, so just try it. If the frequency response is not right, you'll hear it immediately - if it is, enjoy Smile
(actually I believe the crystal pickup mode should be flat)
--mika
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Jul 2 2013 9:46 AM
Yes they will be the same. You can use it for a CD.
Lycka till!
//Bo.
A long list...
vikinger
Posts 5,422
OK. I'll stand corrected. My BM1200 is packed away at the moment, but I cannot actually remember seeing a switch for the gramophone input!
Was it something incorporated in just the first BM1200 models?
Graham
Laban666
Sweden
Posts 15
Laban666 replied on Tue, Jul 2 2013 11:47 AM
I don't know, but I have 5 BM1200 and 2 BM1001 and they all have the high/low switch.
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Jul 2 2013 1:25 PM
5 1200s! Do you know Martin? Smile
Peter
Page 1 of 1 (8 items) | RSS
