BeoSound9000 aux input
magnusvest
Posts 2
magnusvest Posted: Tue, Jul 2 2013 9:36 PM
Hi!
Is there any one who has a good idea how "add more" innputs on a BS9000 ?
I was thinking of a 4 to 1 rca splitter of som type, with the DIN plug in one end
Is there any one who has a better way to solve this?
Magnus
Millemissen
Flensborg, Denmark
Posts 14,680
TWG
Posts 1,672
TWG replied on Wed, Jul 3 2013 10:30 AM
You can also add any preamplifier of some kind (if you have the space in a rack or s.th.) to expand the inputs.
I'm using a Sony TAE-2000ESD as an aux-input-expander on my Beosound.
It's relatively cheap to get (about 150-200 Euro), completely remote controllable, you can enter clear names (9 digits long) for the corresponding source (e.g. "Playmaker", "Airplay", "Sonos", "BluRay"...), you can switch the sources on the unit, you can choose between analog and digital input (very handy for that lousy airport express analog out) and family members don't have to remember how to access which source: It's cleary written in the display :-)
With a lintronic box you can learn the remote codes and program your Beo 5 or Beo 6 accordingly or control it via lintronic box and Beo 4.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
These occasionally show up on eBay.   Allows 4 sources and has DIN inputs & output.   You'd need RCA --> DIN adapter cables to connect your sources to it.
magnusvest
Posts 2
Thanks!
Page 1 of 1 (5 items) | RSS
