If it had been correct or better then B&O would have used it.
It's not always easy to predict or even explain what will happen soundwise, you will have to take a look atthe schematics and I don't have them here, but replacing 37uF with 82uF willkick both the crossover frequencies and the impedance matching over the fence.That's safe to say.Generally a larger capacitance will allow more energy and deeper frequencies through soif one or both of these caps work with f.e. the tweeter, they will allow some midrange and maybeeven some bass energy through to it. This will cause distortion because it overloads the tweeter andthe tweeter will potentially be destroyed if you go beyond a certain volume.
But why not put in the correct values ?
Thanks Martin
