beogram 7000 lifting up the plate
erandlux
Posts 116
erandlux Posted: Mon, Jul 8 2013 8:30 PM
Hi guys,
I just receive my beogram 7000, but it sems the plate is too low in reference too the chassis.
when the arm arrives in the middle of the record, I have a griny sounf like if the metallic plate was scratching against the chassis.
I have red a post with the same problem on a beogram 6500, but it seems it is not the same way to solve the problem.
there is certainly a way to rise up the plate, but could not find it
thanks for your help
Eric
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jul 8 2013 9:04 PM
1. Check the transit screws are released.
2. Check the carriage is properly located on the rails.
3. If the platter is still too low, adjust the leaf springs - if necessary a slight tweak upwards should suffice.
The 7000 is identical to the 6500 except for the badge.
Peter
erandlux
Posts 116
OK, i found them.  The L screws, not the M  Grrr
http://archivedforum2.beoworld.org/forums/p/5351/48110.aspx#48110
it works good.
I will clean my records, and enjoy.
thanks
Eric
Page 1 of 1 (3 items) | RSS
