Hello.
Can someone please tell me what I have to add to the beo 4 to be able to go through sound settings (bass/treble/loudness) and be able to store them from the remote.
Also the procedure if possible once it has been added to the remote.
I have never had a need for it in the past, but I think it would be very handy so I don't have to get my big bottom off thew sofa.
Will this also work for a beosystem 6500, as the remote seems to control all the functions?
Danke!!
A SETUP
//Bo.A long list...
Thanks so much. I will try it my good Swedish friend. Danke.
