Beacord 9000 display poblem
This post has 3 Replies | 0 Followers
Mikemaxcel
Italy
Posts 16
Mikemaxcel Posted: Wed, Jul 10 2013 12:18 PM
1.When powered-up,the 3rd digit of the counter does not light up,previously it lighted up normal.
2.Both the audio dB levels do not response correspondence  to the audio signals,
  seldom go beyong -20 dB.I did get normal response once yesterday when I reconnected the cables of
  PCB-.8004268,the one behind the main display PCB and gone when redone again the same procedures.
The playback is normal.
Anyone here has any suggestion where should I check to get it done.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jul 10 2013 4:04 PM
Welcome to Beoworld !
First let me ask why you disconnected a PCB ?
Did you check the input selector switch at the lower front of the Beocord ?
Mikemaxcel
Italy
Posts 16
It·s just because the display does not function properply and thinking that pins oxidation might cause the problem.
The input selector switch was at the AUX when playback.
Dillen
Posts 13,191
Dillen replied on Wed, Jul 10 2013 5:09 PM
You will have to put a scope to the display strobes to see if one is missing.
The input signal selector has no influence during playback. It's position is important during recording, though, where
it must match the desired input.
If your deck has the level switch at the back near the DIN socket, check its setting too.
Page 1 of 1 (4 items) | RSS
