Beocord 9000 levels calibration
This post has 10 Replies | 1 Follower
Mikemaxcel
Italy
Posts 16
Mikemaxcel Posted: Fri, Jul 12 2013 7:26 PM
I am now working with one of the two 9000 I have and this working unit is the version 4814 which I guest
was manufactured in 1982.
In the stage of levels calibration I just couldn`t  locate the TP3 and TP4 on PCB2 on the deck.
What a frustration.
Martin_Dillen could  help me to solve this.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 12 2013 8:20 PM
Two versions of Beocord 9000 exists.
Can you please tell me the serial number of your Beocord ?
Mikemaxcel
Italy
Posts 16
My is Beocord 9000 version 4814
serial:2719006 Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4
Mikemaxcel
Italy
Posts 16
serial2719006
Dillen
Posts 13,191
Dillen replied on Sat, Jul 13 2013 9:34 AM
You have the early version, then.
There's not always a dedicated point or pad on the board for the testpoints.
TP3 and TP4 is found on pin 3 of IC101 and IC201 respectively. That's the Dolby ICs.
Mikemaxcel
Italy
Posts 16
Mikemaxcel replied on Sat, Jul 13 2013 10:31 PM
Thank you for the information.
Mikemaxcel
Italy
Posts 16
What are the Dolby IC that used in this version of Beocord 9000?
Dillen
Posts 13,191
Dillen replied on Wed, Jul 17 2013 5:02 PM
No.
The testpoints ARE at pin 3.
Pin 3 has a small decoupling capacitor to ground, it's not connected directly to ground.
The thick bottom line on the schematics (that it also "connects to") illustrates a "wire loom" with
several connections and the small notes tell you where the individual connections go.
From 2IC101 pin3, the connection (which is also TP3) has note j-D1 which means that it goes
to point "j" on Diagram 1 (that is pin 1 on 13IC7).
Mikemaxcel
Italy
Posts 16
With the 200nWb/m  level Test  tape,I should adjust 3R160 (3R260)
to580 mvolt.
Mikemaxcel
Italy
Posts 16
Martin,
For meter levels calibration,
where to locate the 2TP1 and 2TP2?
Dillen
Posts 13,191
Dillen replied on Wed, Jul 17 2013 6:43 PM
2TP1 on 2IC102 pin 9 & 10 (they are connected together)
2TP2 on 2IC202 pin 2 & 3 (they are connected together)
Page 1 of 1 (11 items) | RSS
