BeoGram 1203 Tonarm connectors
Menahem Yachad
Jerusalem, Israel
Posts 1,249
I just picked up a throwaway BG1203 - actually 2, and I hope to get one functional unit out of them. They're both falling apart with lots of loose bits inside.
If anyone wants spares - let me know, and what I have left over when I'm finished, you're welcome.
Here is something I've not seen before. It fits into the 4 holes normally for the SP cartridge. Neither of the TT's had an SP cartridge attached.
Does anyone know what this is? I thought maybe an adapter for a non-B&O cartridge.
And of course, if anyone has any tips to save me some headaches while restoring this, I'd be most appreciative.
Menahem
DMacri
United States
Posts 881
DMacri replied on Sun, Apr 1 2012 2:53 PM
That is the inner workings of the cartridge. The needle portion slides over that portion and is held in place by a small screw on the bottom. That type of cartridge was made to allow easy needle replacement.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Thanks!
So now I understand that I need only the Shell, and a stylus, right?
tournedos
Finland
Posts 7,357
All you need is a (complete) stylus. It includes the metallic outer part that is missing from your picture.
Perhaps the pic under SP6/7 is enlightening:
http://www.beoworld.org/prod_details.asp?pid=711
--mika
Page 1 of 1 (4 items) | RSS
