Cleaning aluminium surfaces
This post has 12 Replies | 4 Followers
mscili
Basel, Switzerland
Posts 35
mscili Posted: Fri, Jul 19 2013 2:15 PM
Good afternoon everyone,
while working inside my Beomaster 8000, I decided to take a bit care of the optics too and I noticed that I'm unable to clean the aluminium plates in an effective way. I only tried the "soft" until now (soft cloth with warn water and a bit of dish soap). The markings you can sse in the picture below just stay there... What can I use a bit more aggressive?
Thanks for your help,
Marco
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Jul 19 2013 4:57 PM
I use a "magic sponge"!
Mr. Clean® Magic Eraser Bath Scrubber
Jacques
Michael Sean
Lowell, Massachusetts, USA
Posts 31
I've had great sucess with this partiular "brushed" aluminum surface using the Mr. Clean Magic Eraser. It is also known as melamine foam.
I used it on my BeoSystem 5500 top panels, rubbing agressively with the grain. It has no abrasives but did a fantastic job of removing years of dirt and marks. Also works great on the BeoGram record decks with the brushed aluminum platter surrounds. I have not tried it on the platters though.
Michael
sonavor
Texas, United States
Posts 3,732
sonavor replied on Fri, Jul 19 2013 8:31 PM
It also works good on cleaning a phono stylus.  For that you don't brush the stylus at all.  You dip the stylus onto the magic eraser material - straight in and straight out. No lateral movement at all. It works really well. Since the magic eraser comes in a large block I just cut off a small piece to place under my stylus so I can just dip the cartridge and stylus down on the eraser material easy.
Steffen
Denmark
Posts 1,408
Steffen replied on Fri, Jul 19 2013 11:28 PM
Michael Sean:
-and you shouldn't...Wink
The platters has some kind of coating - even less agressive cleaners can ruin it. And it might end up looking terrible...I've tried once... Crying
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jul 20 2013 12:17 AM
Yup, I ruined the platter on my Beogram 3000 tangential years ago. Fortunately that was long enough ago that B&O had spare platters still available and I was able to get a new one. Whew.
Jeff
Søren Mexico
Mexico City
Posts 6,411
Steffen:
Michael Sean:
I have used it on platters without problems, but there may exist different coatings on the platters, try the backside first.
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf replied on Sat, Jul 20 2013 1:12 AM
The platters definitely have a coating. My Beogram 8000 after 18 months in storage looked like it was diseased. I tried cleaning it and every attempt only made things worse. I had to acquire anther platter as a result.
One thing I have tried with success is Old English Lemon Oil. This is a petroleum-based product which does a splendid job on the veneers but it also cleans/polishes the aluminum.
I am a little concerned that the aluminum panels on my Beocords are also coated, so I use this product sparingly and not often, but after five or more years the effect has only been positive.
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Søren Mexico
Mexico City
Posts 6,411
Piaf:
I have used thinner, ISPA, white gasoline, and just about any cleaning soap on the aluminum on Bms, Beocords and TTs,and no problems. But never on the platters, they seam to be quite sensitives, I never use abrasives, if you do, you will have to do it all, and text and symbols may disappear, and you will have to grind it down to bare aluminum, which will start oxidizing within a couple of years, protected with oil or whatever. And will never look the same.
Piaf
Posts 2,639
Piaf replied on Sat, Jul 20 2013 1:32 AM
Thanks Søren,
I rather thought that must be the case, but I really appreciate conformation coming from you!
Jeff
bidstonhall
Thailand 5560 miles from Struer
Posts 363
I had great success cleaning up a beogram 1902 platter that was covered in duct tape, looks fantastic now
tried the same method with a beogram 3300 and made a terrible mess of it
be careful
MediaBobNY
Greenwich Village, NYC
Posts 1,106
I've washed platters using dish soap with success.  I think part of the secret is to use cold, not hot water, and to dry it quickly or else it will spot.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Jul 20 2013 2:22 PM
MediaBobNY:
That's what I did with mine Bob and it's still looking perfect after a year Whistle
Brengen & Ophalen
Page 1 of 1 (13 items) | RSS
