mr_anders_son:The New Beoremote 2.0 is on App store now!! BeoVision 11-55....BeoLab 14 4.1....BeoPlay S8....BL 6000....BV8-32....BV6-26....Beo4....Beo4 Cinema....BeoLink 7000....Serene....BeoSound Ouverture....BeoGram 4500....H6 Bronzed Hazel....Form 1....U70....BeoLit 600...
Yes I have the BL gateway but I don't have a beoremote one only a beo4 1710
MCB:Yes I have the BL gateway but I don't have a beoremote one only a beo4 1710
mjmedlo:Has anyone tried the epg in the US?
Razlaw:I just installed the App and tried it. EPG seems to work very well.
Beoremote 2 is now an universal app, installs also on iPhone.
Yes it installs now on iPhone. Works quit good and easy on iPhone. The Polymote app I used previously doesn't seem to work anymore after the update. It sees the BV but the app only hangs while trying to connect. The Beoremote app itself seems really improved however,
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Amazone:The Polymote app I used previously doesn't seem to work anymore after the update. It sees the BV but the app only hangs while trying to connect.
there is an improved version of PolyMote on its way to the AppStore. Should be available by the end of next week.They have changed parts of the protocol which causes some trouble with the recent version.
The problem I see with the BeoRemote app for iPhone is that you always have to look at the screen of your phone. The areas for controlling the volume and changing the channel are too small and not gesture enabled
BR,BeoMotion.
tobeyone:Have 2 V1's on my network as well as Avant etc, but the new beoremote app only seems to be able to recognise one of these...I think it found them both in previous version!!
