bang & olufsen mcl2a xtra speakers kit
This post has 1 Reply | 0 Followers
Ronnie
Milton Keynes, UK
Posts 110
Ronnie Posted: Sun, Apr 1 2012 9:21 PM
Hi there,
How does this system connect to a b&o system as i take it that it doesn't have a master link connection?
If anyone could help me on informing me how i connect this system to an Ouverture if possible?
Thanks In advance
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Apr 1 2012 9:33 PM
You will need an ML/MCL converter and some MCL wire. The ML/MCL converter will amplify the signal so you can use passive speakers with your Ouverture. As I had an existing MCL system, I use just this set up with my BC2 and it is fine. The amplifier is not the greatest B&O have ever made but is fine for link rooms.
Peter
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
