Moving Beolab 5's
This post has 11 Replies | 1 Follower
futuristbeo
Posts 16
futuristbeo Posted: Thu, Jul 25 2013 3:15 AM
Can any of you Beolab 5 owners give me some tips on moving the Beolab 5's around? I have to move the speakers from my main floor to the lower level and I want to make sure that I'm careful not to damage them. I certainly realize that I'll have to get some help due to their weight. Where is the best place to grab on to the speakers?Any advice would be much appreciated.
bayerische
Ekenäs, Finland
Posts 4,770
They are supposed to be lifted under the big/lower disc. You'll even find a cavern for your fingers to grip, so that you don't slip.
Too long to list....
Roger
Norway
Posts 417
Roger replied on Thu, Jul 25 2013 10:17 AM
I strongly recommend to have some help if you move them to a different floor without the use of an elevator: It takes two persons to move a BL5 in a staircase.
Roger
Hungedu
United States
Posts 165
Hungedu replied on Thu, Jul 25 2013 5:15 PM
Any move of BL-5 speakers to another room is a two-person job. They're easy to grab hold of under the larger disc with the finger grooves, but the bell shape of the speaker makes it hard to walk with them. You have to kind of waddle with little baby steps. :-)
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Mr 10Percent
So West, Its Now East
Posts 591
If the floor allows it....roll them like a beer keg.
Zero damage to the foot, hands on the grooved outer-disk.
Easy, light, balanced, one-man job
DoubleU
Posts 562
DoubleU replied on Thu, Jul 25 2013 7:58 PM
Good idea! And then to the stairs. If you're lucky you will only hit 3 or 4 steps...
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Thu, Jul 25 2013 8:07 PM
Another trick.. Did this with a Bv7-40 on a stand.
If you have a stone or wooden floor,place a folded blanket under the BL 5 then you can/could maybe pull it slow as far as you can to the stairs before the lifting!
Hope this helps...
olvisab
Posts 1,391
olvisab replied on Thu, Jul 25 2013 8:19 PM
I do prefer the "Obelix technic". One bl 5 at a time on my back !
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
petermc
Australia
Posts 128
petermc replied on Thu, Jul 25 2013 9:56 PM
Also remove any rings and watches to save scratching the aluminium on the discs.
More so when you're lugging it down the stairs and you might have to make a sudden grab to keep the speaker balanced.
futuristbeo
Posts 16
Great suggestions!! Thanks very much everyone for all of the input so far.
Millemissen
Flensborg, Denmark
Posts 14,680
Still not moved? Crying
Doonesbury
Landisville, PA, USA
Posts 168
I've thought about this as well as when I finally get them, I want them in the basement.
I plan on putting them on a dolly/two wheeled hand truck.  There will be some soft of padding between the speaker and dolly so there isn't direct contact between the two.  Then, I plan on putting a rubber hold-down cable around the speaker post (below the lowest disc) to hold it to the back of the dolly.
Hopefully, it will then be straightforward to wheel the speaker around.  Just make sure if you try this that the dolly is designed to handle the weight.  I broke a borrowed one trying to move a cast-iron radiator.  I then went to Lowes and bought two:  one for me and one for the person who owned the one that I broke!
D
Page 1 of 1 (12 items) | RSS
