What Master Link option?
This post has 5 Replies | 0 Followers
mattiasf92
Posts 20
mattiasf92 Posted: Thu, Jul 25 2013 4:51 PM
I have a Beosystem AV9000 together with the Master Panel AV9000. I Wonder what Mater Link option i shall use. The Master Panel AV9000 is connected trough a Master Link cable and is standing in the same room.
Also, do I set one option, like option 2 for the entire system or do I have to set separate options for the audio/video system?
Thanks!
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Jul 26 2013 7:29 AM
AV9000 should be set to V.OPT 2 by default if you have a connected MPAV. The MP does not have an ir receiver on its own, it is not a Beosystem like the 2300/2500. It simply is a remote for the AV9000 with integrated CD player and Radio. It is controlled by the AV9000 ir receiver via Masterlink.
Stefan
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jul 26 2013 12:43 PM
Just a little remark: if you got the MPAV later on and a new masterlink cable it might not work...
See THIS THREAD in the archived forum.
Ralf
mattiasf92
Posts 20
Thanks for the help!
I know the Master Panel doesn't have an own ir reciever like the overture and the others. The reason why I'm asking about the masterlink option is because i can't get my Beolink 7000 to work two-way with the audio sources. It did at first, but after I removed and added components on it, i only get two-way communication for my video sources. Otherwise my AV9000 system works perfectly. After checking the ML Option it was set to V.OPT 2 and the Master Panel AV9000 does not work by remote in any other mode.
At first I tought it could have been the ML Option that was set wrong, blocking two-way communication for the Master Panel, but after checking my other B&O products around the house, the remote works two-way with the other televisions but not with the other audio systems. It's probably something wrong with the remote. I bought it dead and I've just fixed it, but maybe there's something else wrong with it.
http://archivedforum2.beoworld.org/forums/p/6710/60226.aspx#60226
Anyway, thank you. Now I know the ML Option isn't the problem here. =)
mattiasf92
Posts 20
I think I have the old cable, but thanks anyway! :)
stefan
Posts 2,920
stefan replied on Mon, Jul 29 2013 10:08 AM
mattiasf92:
......The reason why I'm asking about the masterlink option is because i can't get my Beolink 7000 to work two-way with the audio sources. It did at first, but after I removed and added components on it, i only get two-way communication for my video sources. Otherwise my AV9000 system works perfectly. After checking the ML Option it was set to V.OPT 2 and the Master Panel AV9000 does not work by remote in any other mode.
Sounds like you have configured your BL7000 to audio-one-way by changing components (?). It is possible to use BL7000 for video in two-way mode and audio one-way and vice versa.
I recommend to delete all audio components in your BL7000 - store - and ADD all audios again while your AV9000 system can "see" your BL7000 and will store AUDIO in two-way mode.
Hope this helps
Stefan
Page 1 of 1 (6 items) | RSS
