Hi Guys.
Using link from Beocentral to B&O for old products shows the new common page.
Any idea what happen to the old pages and how to get into them again?
Best summer regards, Leif
Bang & Olufsen changed the homepage quite a while ago.
You can't get 'the old' back again - why would you want it?
The OP points out that if you use the links to the B&O page for a vintage item, it no longer opens the page for the vintage item. Instead the homepage comes up...
This means we can no longer utilise the links to go directly to the B&O page for a particular vintage item.
x:________________________
Oh - that is what Leif meant
Sorry for for not being as 'bright' as you - maybe it is the heat that does it.
Thanks Jonathan: You just got it right!
