B & 0 RG 900 radiogram
arnold2605
Posts 6
arnold2605 Posted: Tue, Jul 30 2013 8:41 AM
Can anyone tell me where I can buy or have repaired the four damper rams from the two lids on the radiogram. They work up to a point but they all judder quite badly.
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jul 30 2013 9:15 AM
On mine, the metal rod is just an interference fit inside a rubber sleeve.  Is yours the same?
 If so, you should just be able to source and replace the rubber (car bulkhead seals I suspect).  If the rubber has hardened you can get rubber refreshing solutions to soften it again.  Try cleaning the metal rods to ensure they slide properly and smoothly.
Dave.
Page 1 of 1 (2 items) | RSS
