Hdmi over cat 5e
frog
Camberley UK
Posts 624
frog Posted: Wed, Jul 31 2013 5:52 PM
any advice on which cat 5 encoder/decoder would be best to replace the coax ML solution I'm using right now? I have cat5E UTP in the wall, so I think I'll not be sending the data uncompressed! There is either a ip packetised option where you can use a switch, or a HDBaseT standard where it uses its own packet format, so needs to run as a separate physical layer. I'm happy with either, but just wondering if anyone has any recommendations?
regards to all
BeoMegaMan
Posts 601
Atlona products work great for HDMI over CAT and are supported by B&O directly. Geffen or Key Digital products have worked great in the past as well.
Ah, you know... A little B&O here, a little there
Page 1 of 1 (2 items) | RSS
