Does anyone know how to determine what the specific cartridge model number is on a Beo 5500 record player? Im told that it can be a MMC 1,2,3,4 or 5 but I don't know how to inspect the cartridge/player to determine which number it is. Thanks.
The specific MMC number is written on the top of the cartridge.
1 being the top of the range and 5 being the more basic (cheaper model). I think the internals are the same for each cartridge but the diamond and suspension differ depending on the MMC version.
They are all interchangeable.
Dave.
