Beomaster 8000 Project
This post has 257 Replies | 4 Followers
sonavor
Texas, United States
Posts 3,732
I actually was certain the problem was with the P21 cable assembly so I swapped it with a spare I have. Thinking the problem was solved, I returned the Beomaster to the SC80 cabinet and was ready to enjoy the 8000 system again. After a few minutes of happiness though, the left channel dropped out.
Here is the P21 cable assembly.
sonavor
Posts 3,732
I went back to the bench with the BM8000 once more and was determined to find the problem source. This time I noticed the P15 connector could be moved and return the missing channel. After experimenting with the P15 connector (rechecking solder joints and the cable wires), I determined that I couldn't fix it in its current state. So I decided to change both the P15 cable connector and the preamp mating connector.
sonavor
Posts 3,732
It has now been over four weeks and the Beomaster hasn't failed since this last fix. This goes to show that being a fan of vintage audio often requires repeat visits to fully get these nice machines back to full use.
-sonavor
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Very true! Repeat visits are not uncommon.
Just proves how much they want our love and attention!
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Very nice replacement components in there!
sonavor
Posts 3,732
sonavor replied on Fri, Nov 14 2014 5:21 AM
Menahem Yachad:
Yes, demanding beasts they are. Gotta love em.
-sonavor
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 14 2014 8:22 AM
Yes. They do require a bit of attention.
I'm picking up another BM8000 next Monday. What will I find this time?
Jacques
sonavor
Posts 3,732
sonavor replied on Fri, Nov 14 2014 5:22 PM
chartz:
I detect that you have advanced symptoms of the Beovirus.  You finish a repair (a BM8000 in this case) and the virus instructs you to search out and find another one to repair. I am caught in that loop as well.
-sonavor
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 15 2014 2:41 PM
Is there a cure for this rare desease?
Where is research standing?
Jacques
sonavor
Posts 3,732
sonavor replied on Sat, Nov 15 2014 3:32 PM
chartz:
The only known cure is extreme - You have to move to a remote island that has no electricity. Meanwhile, the research has fallen apart as all of the researchers have contracted the disease and are now actively working on their B&O projects.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Nov 15 2014 4:32 PM
I have two spares (defect) that could be used for donor parts in case of.
Brengen & Ophalen
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 15 2014 4:55 PM
That did no fall on deaf ears Leslie! Stick out tongue
Jacques
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Nov 15 2014 5:08 PM
Just let me know or else I will throw it in the bin...
Brengen & Ophalen
sonavor
Posts 3,732
sonavor replied on Sat, Nov 15 2014 11:41 PM
Leslie:
Don't throw anything into the bin. I have another BM8000 waiting for restoration as well.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Nov 17 2014 4:09 PM
I took delivery of the Beomaster 8000, a rather tatty example, but a good reserve of parts for the future. It powers up, the processor works too. The display is defective, with many segments missing.
Someone unsuccessfully tried to open it... Surprise
Jacques
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Mon, Nov 17 2014 6:32 PM
sonavor:
chartz:
Running out of space does not cure the disease, but it does treat the symptoms.
sonavor
Posts 3,732
sonavor replied on Mon, Nov 17 2014 6:38 PM
One thing I remember about my own BM8000, the cable(s) from the control panel can affect those segments lighting up. As I was getting mine refurbished I kept seeing the segments come and go. I was wondering if the displays were going out. Once I got the receiver completed though, the segments all worked. That doesn't mean it will always turn out that way but I would hold off on dealing with the displays until the end. One way to check them sooner though is to remove them from the board and check them in a test jig that powers all of the segments. That's what I did with one of the Beomaster 6000 units I repaired.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Nov 17 2014 7:18 PM
I'll look into that John, thanks!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Nov 18 2014 9:04 PM
A closer inspection of the innards shows that the amplifiers boards were restored at some point, with new capacitors and trimmers. The output darlingtons seem to have been replaced. Not a very clean job I have to say. The rest of the receiver was not modified or restored.
The left amplifier remains completely cold (no sound) with a normal offset voltage. The right amp works but quickly gets lukewarm. I know it should not. It is not a Beomaster 6000!
I'll have to delve deeper into that.
Jacques
sonavor
Posts 3,732
sonavor replied on Wed, Nov 19 2014 6:24 PM
Right, I understood are working on another BM8000.  I only mentioned the BM6000 with regard to a jig to test the display segments.
On your BM8000, are you getting the two channels through your preamp stage?  Just wondering if it is isolated at the output amplifier boards. You might need to recheck the mounting of the output transistors to the heatsink.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Nov 19 2014 7:13 PM
And I was referring to the heatsinks of the BM6000, always lukewarm! Big Smile
Jacques
sonavor
Posts 3,732
sonavor replied on Wed, Nov 19 2014 11:27 PM
haha...too much mixing of Beomasters
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 23 2014 10:56 AM
Have you come across this?
http://vintage-radio.net/forum/showthread.php?t=110262
Tim is the best!
Jacques
sonavor
Posts 3,732
sonavor replied on Mon, Nov 24 2014 7:36 AM
No, I had never seen that link. Very interesting and quite amazing really. I have wondered if someone with the right know-how had ever recreated one of the B&O processors from the eighties. Now I know.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Nov 24 2014 4:18 PM
Tim is well known amidst B&O circles in England. He wrote the B&O collector's bible, as well as many articles for Hi-Fi World and Hifi News.
My tatty Beomaster 8000 now almost work. The important bit - the amplifiers work fine. There were really messy repairs, which were supposedly meant to work! Fortunately, the new components (many transistors, all the TIP 141 and 146) were still fine, and I suspect the repair was aborted. In fact, the previous repairman had broken PCB tracks in several points. After repair the power modules work. He (she? nah!) even replaced the trimmers and the caps, which was a good idea!
Two remaining issues: the missing LED segments, and only static on the tuner. Yes John, I checked the small transformer leads!
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
Tim is the best!
Consider the hours he must have used for this project, not to speak of the time used before and during the project, thinking about it. I have a couple of times done "impossible" repairs on printing m/cs, reaching sometimes the point where the client declines to pay for my time. But as you have an idea and you are sure the solution is around the corner, you just goes on, not thinking about time and effort (or payment). Some of the members on this forum, has the same attitude as Tim, we never give up, and looks for solutions for the "impossible" . You dont have to be crazy to do it, but it helps.Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Nov 25 2014 11:04 PM
Crazy eh? Yes, possibly so. But I feel a bit like Steve Jobs in a reverse kind of way, we are the crazy ones, the misfits who believe that ancient devices still have something valuable in their guts, that they still have something to say. They have a soul.
Tim, Martin et al, great purveyors of parts and advice, believe in that too, and keep helping us, day in, day out. Let me thank them for that!
Back to business then.
A change of U264 - I had one spare - has not resolved my tuner issue. No control over input voltage to the varicaps, whilst displaying the whole frequency range.
I feel that I am on my own here.
Jacques
sonavor
Posts 3,732
sonavor replied on Wed, Nov 26 2014 4:57 AM
What are some more details of the failed tuner?  You're getting the FM station but not the correct display?  Or are you not getting anything from the tuner?
I just got a Beomaster 6000 back to full operating condition last night. The last thing I had to do on that one was replace the tuner signal cable (the 2-wire one inside from the tuner board to the processor board) because the cable was bad. So double-check the cable in the BM8000 if you haven't already. Also, the cable from the control panel to the processor board in the BM8000 can start breaking at the board connection. Sometimes it is hard to see that one of those connections is broken. If you are seeing the frequency jumping around it could be that control panel board connection to the processor board. On my BM8000, I finally just detached that cable, stripped new leads and re-attached it.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Nov 26 2014 7:18 AM
Thank you John.
Every single wire was duly checked. In fact, they are the first elements I verified. I know about the BM6000 cable, I had the same problem, with the digits displaying 74 MHz or something like that.
I get static (hiss) in manual, and no MPX or multipath signal. Of course, no radio. The galvanometer is good though.
I will have to test the tuner boards.
By the way, what do you say to a TP2 input that has less treble on both channels, along with a narrowed stereo image, than TP1?
The preamp boards were fully re-capped, but it made no difference whatsoever.
Jacques
sonavor
Posts 3,732
sonavor replied on Wed, Nov 26 2014 7:50 AM
chartz:
Does the Phono input work okay?  If the phono path is fine then I guess I would check out and try replacing 3IC1 OpAmp. You've already cleaned the input level trim pots (3R122 and 3R222), right?
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Nov 26 2014 8:14 AM
So I'll try replacing the op-amp then, the rest being okay. I was thinking along the same lines here, input electronic switch IC, then op-amp on TP2 line. Still I wonder how a partially defective LF can degrade sound quality that way...
Thanks!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 29 2014 3:08 PM
I thought I was about to solve the tuner issue. I found that the tuning voltage was never arriving from the connector to the front end. So I grabbed a magnifying glass and found this.
False hopes... After repair, still nothing but static. I can now see voltage at the right places, but all I can get is Vmax (22V) and Vmin (3V) before and after about 91 MHz. But this time, no zooming of radio stations.
The signal meter stays idle. It is good and the needle responds to voltage from an exterior source.
I did replace the pre-scaler (twice so I'm sure) and the 4013 flip-flops.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 29 2014 4:28 PM
We have a shorted TDA1062! The 47Ω protection resistor was duly burnt, but it was difficult to see. A voltage test revealed that.
Mmmm... Don't have that in stock Angry
I'm not sure what caused the internal transistors to burn. It is shorted between PIN13 and ground. What are R6 and R11 anyway?
Is it a fragile chip? B&O fitted a protection resistor for a reason, didn't they? They knew something that we don't!
Jacques
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Right here for you, in France.
http://www.ebay.com/itm/TDA1062-Tuner-FM-CTDA1062-/180788694030
I've bought from him a few times - quite reliable, and has most of these obsolete B&O parts.
Menahem
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 29 2014 4:49 PM
Hi Menahem,
I've already ordered from him too! Thanks for the link! Smile
Jacques
chartz
Burgundy, France
Posts 4,171
Ordered placed! (in fact, double post but I've found something else to say Stick out tongue)
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 30 2014 2:15 PM
One more component to replace. Let's hope it's the last one... There must be some logic here, but I don't see it.
The other transistors appear to be fine. I have tested the coils as well: I had a doubt about L7 but it is fine.
Jacques
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Did you replace those trimmer potis?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Nov 30 2014 2:37 PM
I usually let the tuner trimmers well alone. I don't have suitable equipment to handle FM circuits.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Dec 5 2014 8:46 AM
The new TDA1062 arrived yesterday. Then again, B&O fitted a protection resistor (R21) for a reason, I'm pretty sure that they knew the failure mode of that Telefunken chip! I think this is a first on the forum!
And the repair is a success!  Smile
The tuner now works (as usual, even without any aerial, it pulls in a few stations) and the meter and MPX beacon are back.
Pre-sets work to.
I now have a rather tatty Beomaster 8000 that is fully functional. I need new wood trims (the right one is fine, the reveiver was stocked standing on its left side, oh dear, can you imagine? Well, I sore it! (for Brits only) and the display misses a few segments.
The top is okay, not sctatched or anything, except that someone tried to lift the middle bar with a screwdriver. Sometimes... Angry
Jacques
Page 6 of 7 (258 items) « First ... < Previous 3 4 5 6 7 Next > | RSS
DigiCert Secured Site Seal
