Beo5 dock
This post has 7 Replies | 2 Followers
tomasarnason
Posts 1
Silver Member
tomasarnason Posted: Tue, Apr 3 2012 1:03 AM
I recently accuired a Beo5 remote, but I didn't get the dock with the USB connection. Does anyone know where I can get one. I really want to edit the menus and commands on the remote. I think that the local dealer want's to charge his customers as much as he possibly can so buying the dock from him is either not possible, or would cost me a fortune.
So, any advice?
CasperI
Posts 93
CasperI replied on Tue, Apr 3 2012 6:20 AM
You don't need a "USB dock", as the table charger consist of 2 parts. A cable with a main plug and a MINI-B, and a cable with MINI-B (female) and table charger.
All you need to buy is an adaptor from USB to MINI-B. Like this: http://www.kenable.co.uk/images/CDL-062.jpg .. Then your'e good to go Smile
paulwhitehead
Posts 170
exactly right Casperi
a simple and cheap connector will allow you to hook up to your computer.
Paul
bjorklund
Posts 2
bjorklund replied on Wed, May 9 2012 10:18 AM
I got my Beo5 with wall mount and its not possible to connect with USB. Had to buy the table stand to program it :(
Chris Harrison
Peak District
Posts 381
What does the beo5 wall mount look like?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
hfat
Vienna, Austria
Posts 663
HI,
There's a picture, rather small but you can see....
hfat
Nicolas
Switzerland
Posts 9
Nicolas replied on Wed, May 23 2012 4:55 PM
Here is another view :
Nicolas
BeoVision 12-65 / BeoLab 9 / Beo6 / BeoCom 2 / AppleTV 4
Chris Harrison
Peak District
Posts 381
I really like those wall mounts. Very nice and quite rare.
Page 1 of 1 (8 items) | RSS
