Beocom 2 reset and connect to station, how?
This post has 8 Replies | 0 Followers
acey
Posts 5
acey Posted: Tue, Apr 3 2012 1:54 AM
Hi, need to add another beocom 2 to my station.  I forgot how to get to the menu to reset the phone, and connect to station
something like #9#0 etc.... ok.  anyone here remember?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
I think it's the same command as a Beocom 1:
9#9#9*HOLD
acey
Posts 5
acey replied on Tue, Apr 3 2012 4:24 AM
thanks!
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Wed, Nov 14 2012 4:18 PM
I hope it is ok to borrow this thread,
I need to change the language of a BeoCom 2. I the users manual it says that I need to go to the "handset setting" on the phone. But there is no hand set menu - only the normal settings menu... I only got the base unit for the phone. Is there any way to reset the phone so I can change the language?
I tried the 9#9#9*INT but I could not see any reset option there either.
Hope you guys can help Smile
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Emil
Posts 135
Emil replied on Wed, Nov 14 2012 10:38 PM
Hmm, I believe you should be able to change the language under "settings" in the normal menu. Last menu option when you scroll down in the menu settings. No need to reset the handset as far as I know.
MediaBobNY
Posts 1,106
You might need to reset the handset to get back to the first-time setup options.   9#9#9*HOLD
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Thu, Nov 15 2012 2:58 PM
I have tried the reset option 9#9#9*INT (same as hold?) But that only takes me to the service menu. I can't see any reset option there either.
In the normal menu I am not given the option to change the language Sad
The production date is 01/2001
MediaBobNY
Posts 1,106
MediaBobNY replied on Thu, Nov 15 2012 10:18 PM
On mine there's a hold button so apparently there are several versions.  Try the button to the left of the R.
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Fri, Nov 16 2012 11:18 AM
When I pres the button next to R it just makes an = on the screen. Nothing else happens.
Page 1 of 1 (9 items) | RSS
