After one year of not using my beocenter 2500, which always worked like a charm before, I ran into a problem this afternoon.
The system does not produce music anymore :( instead, all i get if I turn it on is a lound buzzing / humming noise from both speakers. I can "regulate" the buzz volume with the volume rocker, but regardless of the audio source I choose, all I get it the humming!
Since I could not find a thread about this problem I am reaching out to the community, hoping that someone has an idea what is causing the problem or has already fixed one showing similar symptoms!
Your help would be greatly appreciated,
Thank you in advance, regards, Wolfram
