hi, i wasnt sure if to post this in general or mac, so ive gone with mac...
ive managed to get the Apple TV playing on the Beovision 10 via a HDMI cable but Ive only got picture and no sound. Does sound transmit over HDMI? is it just a setting somewhere or do I need another cable?
Im sure my Sky Box runs sound and picture through 1 hdmi cable?!?
Thanks for any help
I've got a BV11 with Apple TV connected through HDMI, and yes sound goes through HDMI. There should be no difference between BV10/11!
I'm not familiar with BV10, but have you run through all the settings for Apple TV on the BV and in Apple TV menu?
after a lot of messing about in the settings, i went to S/P-DIF and set this to another channel and the sound has started working.... but it wasnt something that worked out of the box
My AppleTV to BV experiences were plug'n'play.
Seems to be a handshake problem. Often hard un-/plugging the cable helps, or using another.
