Signal channel trouble with 1900 Receiver
This post has 9 Replies | 1 Follower
PhilDevoid
Posts 8
PhilDevoid Posted: Wed, Aug 14 2013 1:45 AM
Hi, newbie here.
I have a Beomaster 1900 with speakers too, hand me down. I was worried that one of the speakers was blown, but it is not.
I have a different issue. It looks like it is set up for 2 sets of speaks (1, 2). Now when I plug in the red and black into one of the speaker portals (1, for instance), only one speaker works. The same thing happens when I put the plugs into 2. Now the work-around is if I plus one speaker into 1, then the other into 2, but I fear they are both the same channel. If I adjust the balance on the console, it appears to be the case. Can I fix this easily or should I just bag this beauty? I don't want to spend a lot to repair and would DIY if I could and someone could help. Or, is it SUPPOSED to work like that?
John Francis
USA
Posts 155
Silver Member
Hello,
There are several posts on this forum regarding similar issues and often are symptomatic of the same cause. I just went through this issue myself with a 1900 restoration. Look for the specific problem you are discussing starting on the third page of the following link, under the title Beomaster 1900 Restoration Question, that I posted.
http://archivedforum2.beoworld.org/forums/t/4321.aspx
Most likely it is the slider control for the blance that is the problem or maybe even all 3 sliders, balance, treble and bass. It takes a steady hand but I fixed them with the help of others on this forum. You should find some helpful information in this post, well worth it to fix one of these and saving it from being trashed. Good luck!
John
PhilDevoid
Posts 8
PhilDevoid replied on Wed, Aug 14 2013 12:50 PM
Thanks for this!  I will start digging in!
PhilDevoid
Posts 8
PhilDevoid replied on Sat, Aug 17 2013 12:15 AM
Well, I flipped it upside down, took the screws off the outside bottom, then got a little intimidated.  Unscrewed the black plastic area where the speakers get plugged in but wouldn't pull out, same a bit with the green circuit board, but I might have been getting too intimidated by that point.
I am a complete amateur at taking one of these apart, could someone give me some guidance at getting to the sliders to clean and see if I can get this channel cleaned up?  Reading the schematics is a wall of difficulty for me.  I would greatly appreciate it.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Aug 17 2013 6:11 AM
To be honest, this is not a job for a novice. And I mean this in the best of ways.
It can be very tricky to get in and even worse to get out.
You assumed that it was like any other stereo and started from the wrong side !
PhilDevoid
Posts 8
PhilDevoid replied on Sat, Aug 17 2013 11:51 AM
Yes, I think I realized that once I opened the back!  Okay, so how to get in the the top?
Dillen
Posts 13,191
Dillen replied on Sat, Aug 17 2013 12:49 PM
Four screws holds the vertical rear grill.
Then two screws under the large alu lid which then lifts off together with the underlying plastic part.
PhilDevoid
Posts 8
Cool, I am in!  I unscrewed the circuit board, but can't really get under due to wires holding it down.  I can't seem to see any burnt out circuits or anything, fairly clean.
Søren Mexico
Mexico City
Posts 6,411
You will need an Ohm meter (multimeter) to check if the sliders are OK, specially the balance.
Dillen
Posts 13,191
Dillen replied on Sat, Aug 17 2013 9:33 PM
There are slots provided to hold the tonecontrol board upright.
You can also unplug it and take it out.
Page 1 of 1 (10 items) | RSS
