Bs7000-bv8-40 problem
This post has 21 Replies | 1 Follower
André S
Roskilde
Posts 35
André S Posted: Sun, Aug 18 2013 11:59 AM
Hey all :-)
i have my Bs7000 connectet to my bv8-40 with helt from the 1611 converter.
The problem os that when i press CD one the beo4 my bv turns one and only my bv and not the bs7000
then the speakers turns one but only a "mmmmmmm" sound is coming of you know what i mea :-/
Millemissen
Flensborg, Denmark
Posts 14,680
Hi situation,
First try to disconnect all from the mains - then reconnect the BV and the BS....
...and finally the converter!
Do you have a ML-splitterbox in your setup?
Greetings Millemissen
André S
Roskilde
Posts 35
André S replied on Sun, Aug 18 2013 6:28 PM
What u mean with ML-splitterbox? :D
but is there some thing that i need to do like option 0-1-2-3 or what ever with the Beo4?
elephant
AU
Posts 8,219
situation:
He means one of these:
BeoNut since '75
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 8:36 AM
Ohh okey :-) But no i dont.
i use a Datalink kabel from beomaster 7000 and up to the 1611 converter.
and then Masterlink kabel from 1611 to the bv8-40 masterlink in
Millemissen
Flensborg, Denmark
Posts 14,680
Well, I actually meant a 'Junction Box', which is the correct name for the little box you use to split one ML cable into 2 or more. Quite often reasons can be found in a faulty connection there.
Anyway, assuming you have no no speakers on the BS7000 in that room, the options are:
Video - opt2
Audio - opt0
Please reed the userguide of the BV8-40 for details - page 36.
If you still have problems try changing the ML cable and/or the AUX cable.
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 10:09 AM
Just to be sure...
it is the Tv/AUX i need to use ind the bm7000 right?
Millemissen
Flensborg, Denmark
Posts 14,680
Yes!
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 10:43 AM
Well is there eny thing that i have to do ind the menu one the bv8?
or eny thing? Im going to try to re-connect all the kabel soon
Millemissen
Flensborg, Denmark
Posts 14,680
No - just setup with the Beo4 as descibed in the userguide.
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 12:35 PM
Hmmm there is still the problem.
but when i turn one the cd7000 and then press CD one the beo4 then there is musik but there is just that stupid hum ind the background of the musik and i dont understand why :-(
Millemissen
Flensborg, Denmark
Posts 14,680
Must ask:
You only ever talk about CD.
Is the problem only with CD, or also with radio...?
Do you have external BeoLabs on the BV8?
if yes - is it there, when you use the internal BV8 speakers only.
Do you have any problems with the sound from the BV8 (and the attached sources)?
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 1:51 PM
do not use radio :-) but beyond that I have forgotten to say that bs7000 does not turn on when I press the CD but only the Bv8 and then the beolab penta and BL2 turns one too like they need to do .. And then the humming sound comes right after
Millemissen
Flensborg, Denmark
Posts 14,680
Next thing -  I would change that converter - if you have access to another.
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 2:19 PM
Well its only about 7weeks old so i can get it fiks or get a new one by the warranty
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Aug 19 2013 2:44 PM
Are you sure that you use a 7 pin datalinkcable connected to TV/AUX on BM7000 and AUDIO AUS LINK socket on 1611?
And did you try an additional Poerlink cable connected to PL/BM7000 and PL/converter?
Your system is set to V.OPT2 and A.OPT0?
When you select another audiosource - same result? (Asked before but ...)
Stefan
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 3:21 PM
I have never try powerlink from bm7000 to 1611 PL in:-)
will it not do some thing bad to it
stefan
Posts 2,920
stefan replied on Mon, Aug 19 2013 4:15 PM
situation:
Sure - it might work!
I`d recommend to search in the old forum and have a look at the PCG.
Can be downloaded here on Beoworld.
I guess you will find exact this information....
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
There is no need for the PowerLink cable running parallel to the AUX cable.
Only gain is that you can turn on the sound from the videosystem, when you start a source manually on the audiosystem, and that the audiosource shuts down, when you switch to a videosource (with the Beo4).
I have had a similar setup for years (actually for decades now) - at first with an Avant and now with a BV8-40 as videomaster, and never got the PL cable connected.
No problems there - on the contrary: I can plug in my headphones to the audiosystem, start the audiosource and turn up/down the volume manually without switching the videosystem on.
I must say that I am at a point where I don't understand, where the problem in the 'situation-setup' can be located.
Next thing I would do is swapping the audiomaster with another. But not everyone has a 'spare' MCL-based audiosystem at hand Crying
Magnus
Norway
Posts 331
Magnus replied on Mon, Aug 19 2013 10:30 PM
Noise in the audio and no control sounds like a cabel issue to me... Are you sure all the cables are properly in their sockets?
Millemissen
Flensborg, Denmark
Posts 14,680
I have asked that - but I still wonder if it is so?
André S
Roskilde
Posts 35
André S replied on Mon, Aug 19 2013 11:21 PM
Im now going to say f*** it and then buy new cables and see if that works and if not im goi g to return the 1611 and get a new one.
i will report back later when its don :-) thanks all for you're time
Page 1 of 1 (22 items) | RSS
