xml generator beo6
manitou
germany
Posts 61
manitou Posted: Fri, Aug 23 2013 11:41 AM
hello,
I have read here in the forum that there is a xml generator for Beo6 available for gold members. which codes (pronto. ..) does it support? and is he comfortable to handle?
then a gold membership would in fact pay off for me.
grüße horst
Rivenflush
Gothenburg
Posts 333
I have used it with Pronto codes from Remotecentral.com. In the software you paste one IR code (button) at the time which through a few steps is then converted into a simple XML file (placing it as soft buttons) which you can either copy and paste into a "real" XML file or just rearrange in the Beo5/Beo6 configuration program.
It's a little work but I think it's well worth the effort / cost.
However, I would appreciate if you wait to become a gold member until next year as I want as few competitors as possible in the battle for the BS9000 in the December prize draw Big Smile.
Best regard,
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
manitou
germany
Posts 61
manitou replied on Sat, Aug 24 2013 10:07 AM
@ rivenflush
thanks,
so you will see me as competitor for bs9000 in the next daysSurprise
grüße horst
Page 1 of 1 (3 items) | RSS
