BeoVision 7-40 setup question
atakacs
Posts 2
atakacs Posted: Sun, Aug 25 2013 9:18 PM
Hello
Pretty new to the whole BeoWolrd (TM) so please bear with me... Embarrassed
I am trying to setup an additional set top box (an Internet TV from Swisscom - the Swiss Telco - but I guess it's not really relevant, my question is probably quite generic) and I just can't really figure out how to make it work.
So this is BeoVision 7-40
My remote look like this
the back-panel is wired like this
My set top box has a (working) HDMI output which I am trying to connect to HDMI A:
Then I am trying to configure it to AV3 / DTV2:
I might be missing something pretty obvious... but how do I select that source to be displayed ? For the life of me I can't figure out how to have that signal displayed !
Again probably a trivial question but any help / suggestion most welcome !
rednik
Posts 182
rednik replied on Sun, Aug 25 2013 9:29 PM
I think DTV2 is V.AUX on your remote.
If setup as shown in your pictures you need to select V.AUX on your remote to view that input.
Press the LIST button on your remote multiple times to scroll through various options which will display on the LCD of your remote.  If V.AUX comes up, press the centre GO button to switch the TV to the correct source.
if not press STANDBY and LIST together so ADD? Shows on the remote.  Press the GO button.
press left to scroll through the options untilV.AUX is on the screen, then press GO to store it.  It should now be an option in your LIST
atakacs
Posts 2
atakacs replied on Mon, Aug 26 2013 7:38 PM
Thanks - I had indeed to ADD this source on the remote - that did the trick Cool
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
