Bit of a long shot... but is it possible to watch one input whilst listening to another?
You can watch one input and listen to another as long as the audio is connected via the masterlink input. select the video source to watch and then select AV on the BO4 remote followed by the sound source you want to listen to.
Ron
I don't use the masterlink input... just the scarts.
there's one possibility when your Avant has a Dolby Digital Modul installed. Then you can connect your Video Source via scart and a different Audio source digital Audio via RCA connector. But that's not very comfortable, you need at least a second remote for the digital Audio source to control it.
Ralph-Marcus
I have an Xbox 360 plugged into v.aux, and an ipod classic plugged into V.tape2 (L&R Audio into scart block)
Don't think my set has a Dolby module.
