Hi everybody,
Is it possible to use a beolink wireless 1 between a pair of rear speakers (receiver) and a beovision 7 (transmitter) for dolby surround sound ?
Thanks in advance for your help
Best regards
OLivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Maybe, but probably not. The Beolink Wiress gets its audio from MasterLink. I'm not sure how you would direct only your rear channels output to ML so the BL wireless can get it. Maybe Steve at Sounds Heavenly has some magic cables that will allow this, but I doubt it.
Stan
Hi
you are looking for this
http://almando.com/index.php/b-o/bo-beolab-wireless.html?___store=endkunde_eng&___from_store=default
Hi Olivier,
The best option here is always to run the correct Powerlink mk.3 cable to the speakers, this cable is only 2.5mm thick so it is easy to hide. You only need to run one cable to the TV, as the speakers can be daisy-chained together from the one cable. If you need any further help, please feel free to ask.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
B&O are about to bring out wireless speakers and the transmitter on the 30th of October.
Peter
