REAN DIN Connectors Issue
This post has 3 Replies | 0 Followers
Redline7700
Posts 31
Redline7700 Posted: Tue, Aug 27 2013 6:21 AM
I recently ordered some REAN 7-pin DIN cables to replace some cheap radio shack MIDI cables but I am finding that my Beomaster 8000 won't accept the datalink info from the turntable or tape deck even though the cables are 7-pin DIN.   Any suggestions?
Here is a link to their website http://www.rean-connectors.com/en/products/din-cable-connectors/nys323
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
There is nothing wrong with the plugs, the problem is with the way the cables have been connected to the plug!
With most B&O systems the datalink conductor should be connected to pin 6 but Beomasters without on board RIAA pre amps should have the datalink connected to pin7.
It is possible to just link pins 6 and 7 together and the cable should work on either system.
Regards Graham
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 27 2013 1:28 PM
- and the Phono cable should have separate signal- and protective grounds.
Redline7700
Posts 31
I took a look inside the cable and only 3 of the 7 pins are actually connected inside. L/R/G on the top 3 pins. So these REAN cables should be avoided.
Page 1 of 1 (4 items) | RSS
