BeoGram 3500 Light
This post has 29 Replies | 0 Followers
Keith
Shrewsbury
Posts 138
Keith Posted: Thu, Aug 29 2013 8:16 PM
I have a BeoGram 3500.
Is it right that the light stays on on dim all the time. It lights up fully for a few  seconds when you press play then does to dim again.
Keith.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Aug 29 2013 8:28 PM
No, it should go off completely.
Keith
Shrewsbury
Posts 138
Keith replied on Fri, Aug 30 2013 11:07 PM
Any help please?
Orava
Finland
Posts 991
Orava replied on Thu, Sep 5 2013 2:00 PM
Wrong value lamp, or leaking driver transistor or wire?
Keith
Shrewsbury
Posts 138
Keith replied on Thu, Sep 5 2013 6:09 PM
The lamp is the one fitted form new, I have checked all the wires and all OK.
The leaking driver transistor, need help to point that one out.
Dillen
Posts 13,191
Dillen replied on Thu, Sep 5 2013 7:13 PM
TR3 (a BC337) but it's not guaranteed to be the cause.
There could be other reasons.
Keith
Shrewsbury
Posts 138
Keith replied on Thu, Sep 5 2013 9:07 PM
The BeoGram works really well, nothing is over heating and it's been like this for over a month.
At the bulb the volts are 11.95 when dim and when you press cue the light comes on full and the volts read 11.98.
I have disconnected  the bulb for over a week now, with no ill affects on playing records.
Should I leave it like this?
Orava
Finland
Posts 991
Orava replied on Fri, Sep 6 2013 6:32 AM
And you did measure with bulb on circuit? Bulb is a collector load in circuit.
Basically it is very simple. NPN transistor is driven from near by big IC pin 16 through R7 and stabiled with C4, thats it.  High/Low only.
Keith
Shrewsbury
Posts 138
Keith replied on Fri, Sep 6 2013 8:38 AM
Yes I did measure the bulb on circuit.
Orava
Finland
Posts 991
Orava replied on Fri, Sep 6 2013 9:14 AM
Maybe you should check pin 16 (end of R7) is functioning correctly.
Keith
Shrewsbury
Posts 138
Keith replied on Fri, Sep 6 2013 9:18 PM
How do I check that?
Dillen
Posts 13,191
Dillen replied on Fri, Sep 6 2013 10:17 PM
A voltmeter from ground to the IC pin.
Read the voltage when the lamp is supposed to go and off and let us know.
Keith
Shrewsbury
Posts 138
Keith replied on Sat, Sep 7 2013 8:26 PM
Sorry for being a bit thick, but is it on the control board?
Orava
Finland
Posts 991
Keith
Shrewsbury
Posts 138
Keith replied on Sun, Sep 8 2013 8:48 AM
And where is R7 on the board.
Dillen
Posts 13,191
Dillen replied on Sun, Sep 8 2013 8:52 AM
R7 is the resistor sitting two components left off TR3, is my guess.
Keith
Shrewsbury
Posts 138
Keith replied on Sun, Sep 8 2013 11:12 AM
Found R7. and the volts are 0.578 when NOT lit and 0.711 when lit from the R7 side.
The other side is 0.059 when NOT lit and 2.635 volts when lit.
Hope this is right.
Keith.
Keith
Shrewsbury
Posts 138
Keith replied on Sun, Sep 8 2013 11:15 AM
Found R7. and the volts are 0.578 when NOT lit and 0.711 when lit from the R7 side of the resistor.
And from the other side of the resistor is 0.059 when NOT lit and 2.635 volts when lit.
Hope this makes sence?
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 7:16 AM
0,578 sounds a little bit too high, I think IC is functioning ok. So maybe tr3 is not ok?
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Sep 9 2013 8:55 AM
So how do I check TR3
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 9:11 AM
Well... I'm not very good with tr's, but if you measure voltage between collector and emitter, it should be near zero when lid, and near 12V when dark. C4 is connected from base to ground, but I cant see any possible cause there. Anyway is possibly 0,578V enough to keep tr partially open, so bulb light dimly.
And because there simply is not anything but TR3.... I suspect it.
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Sep 9 2013 9:35 AM
Can I get hold of a TR3 and replace it?
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 10:21 AM
It is quite common and so expencive that changing it is not problem. Only nasty thing is location, have to remove mainboard....
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Sep 9 2013 11:33 AM
Is removing the board a hard job, and are there any instructions on how to do this?
Where can I get hold of a TR3.
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 12:16 PM
There is that solenoid thing and some adjustments by moving mainboard, so testing is good idea.
I guess any local component supplier can supply these.
Dillen
Posts 13,191
Dillen replied on Mon, Sep 9 2013 1:17 PM
Don't get me wrong, I have a huge respect for DIY'ers but from reading your posts, I feel tempted
to say that this is not a repair job for you.
Removing and reinstalling the board is not particularly easy.
Soldering on a board of this type is not something I would advice for beginners.
Bring it in for service, it shouldn't be too costly a repair.
Maybe another Beoworlder near you can help you.
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Sep 9 2013 1:40 PM
I live in the UK. The last time I was looking for help, someone put me on to a chap that was an X B&O service engineer, It cost me an arm and a leg. They charged me £80 just to look at it.
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 1:45 PM
Yes, Martin is right in that, this job needs considerable amount of disassembling, so one have to be sure it is within  ones limits. Better look than be sorry.
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Sep 9 2013 1:55 PM
Many thanks to you two for all your help.
I will watch Ebay and see if I can find an old unit some time.
For now I will pull plug out and leave the light off.
Keith.
P.S. It still sounds great even without the light.
Orava
Finland
Posts 991
Orava replied on Mon, Sep 9 2013 6:19 PM
Yes, it is great player and light doesnt affect that.
This site is a great resource if you are interested about fixing this old stuff. Maybe finding something from ebay to start with? Your BG is not the best one for that, not most difficulty but not easies either.
Cheers
Page 1 of 1 (30 items) | RSS
