Surround Sound : BL3 Front, what in Back ?
This post has 8 Replies | 3 Followers
Scott Needham
Paris, France
Posts 217
Scott Needham Posted: Thu, Sep 5 2013 1:46 PM
I currently have a pair of BL3 and a BL7 center speaker on my BV7. I am looking to complete the surround sound set-up with a BL11, but what to put in back.
I have read on other posts about BL4, BL4000, and BL3 as Back speakers. I wonder if BL3 would be too much. And BL4 not enough. And I don't have the space tp put anything bigger in Front ...
I would love some feedback and advice. Thanks !
- Scott
Chris Townsend
Qatar
Posts 3,531
I used to have a 7 with 8000's at the front and 6000's at the back. As they weren't that used by Beosystem 3 for the price, footprint and cosmetics they were perfect.
They are currently a bargain at the moment too, so you might have enough spare cash for a Beolab 2. Much recommended :-)
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Thu, Sep 5 2013 2:43 PM
The Beolab 4 sound good for the size but The Lab 4000's are a much better speaker in every way,there again Beolab 3 would be anther jump up in sound and also the ALT on them,which you have at the mo!  Having a set of Beolab 3's all round would be the same in the set up!
Try and borrow a set of Beolab 4's...4000's and of course a set of 3's as well.
I use a Beolab 4000 for my center on the Bv7-32 in the bedroom with 6000's and the 4000 is really great as a single center! There great as surrounds too.
A member called Elephant on this forum has a set of Beolab 4's maybe he will post if he reads this, about his set?
Good Luck on what you decide!
Bv7Mk3
uk
Posts 781
olvisab
Posts 1,391
olvisab replied on Thu, Sep 5 2013 3:11 PM
Hi
The back speakers are not so important. I have the choice between 4 bl3 and bl3 in front with bl8000 in back. FInally I choose the second solution just because I love the look of the 8000 and the bl3 desserves more than the back position.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Frederic
Belgium
Posts 121
I would suggest BL3
- balanced power if you select speaker4
- continued ALT and ice power technology
- last, esthetically balanced as well
symmes
Posts 247
symmes replied on Thu, Sep 5 2013 3:26 PM
I probably like Lab 4 more than most, especially as rear speakers.  I just don't care for the floor stands because of cable management. Plus you could run them through a BL11 for much less than the price of one BL3.  Another alternative is the BL12-1.  Very nice, but you have to convert the cables to RJ45.
ClausMikkelsen
Posts 26
Hi Scott,
I have a BeoVision 8-40 with BL3's as front, BL4's as back and a BL11 - AND I LOVE THEM!!!
I bought a pair of used BL4's a few years ago, because I couldn't afford anything else at the time, and they are actually okay. At some point I want to exchange them for something else, but I don't know to what. Have thought about both BL4000's or another pair of BL3's, but don't want to spend that much money on rearspeakers. Then I would rather buy a pair of BL9's as front, and move the BL3's to the back?! In my opinion the BL4 work great as rear speakers in a surround set with the BL3's and BL11 - alone as stereospeakers, I don't like them at all!!!
If you can borrow a set of BL4's and a BL11, then try them together with your BL3's. Big Smile
Kind regards
Claus
elephant
AU
Posts 8,219
elephant replied on Fri, Sep 6 2013 10:14 AM
Bv7Mk3:
Yes !
I have experimented with BL4s as rears - and even 4 x BL4s (front & rears) to see (sorry hear) the effect of having the same speakers (my fronts are normally BL3s).
Unlike Claus and Symmes I was disappointed.
Maybe it was my choice of test movies.
Maybe I should have left it all running for a month.
So for me there was not enough oomphf !
But for my wife they were too much.
She really hates surround sound - she keeps look behind her to see what's going on Smile
And as mentioned having the right stands and cable management was a problem during my tests.
Another "no no" from the wife.
So I suspect that the BL4s would prove to be adequate - depending on the source movie.
Certainly I am happy with them playing music in small link rooms.
BeoNut since '75
Page 1 of 1 (9 items) | RSS
