Did you correct the vol settings and is ist working now?
hfat
kai:Hi all the settings where at zero and it would not let me correct that, I did go into speaker config and changed some settings then made hdmi as output source going out tomorrow so hopefully that should be it will let you then :)
BeoNut since '75
