Have just bought a used Beosound/Beomaster 5 system and trying to wire up to my TV. Have connected via a master link cable and the Beosound 5 and Beomaster 5 are connected. Beo 4 remote works well enough, but stuck. Do I need to connect anything else to the TV or do I need to reprogramme the Beosound 5?
Help please!
Have you checked the option programming of the tv? Might be that you have to press "av" + a.mem.
You have no BeoLabs' on the BM/BS5 - right?
You want to play through the BV?
Check page 28 of the Userguide for BeoSound5 avaible on the B&O homepage:
http://m.bang-olufsen.com/en/Sound/Sound-systems/Beosound5/user-guides
http://www.bang-olufsen.com/en/customer-service/product-support/sound/sound-systems/beosound-5
Settings for 'AM options.
Greetings Millemissen
