Century
This post has 36 Replies | 1 Follower
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw Posted: Sat, Sep 14 2013 3:08 PM
Thinking of buying one off ebay - I have never heard one before - does it have treble and bass controls?
Cheers
Nigel
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Sep 14 2013 3:15 PM
You can adjust tone, yes.  The Century sounds great - especially when wall mounted.
The only things which play up are the door sensors and cassette decks (which usually clog up with dust!) - but on the whole they are very reliable. It has transit screws, so don't forget to ask the seller to tighten them up (they are on the rear of the unit, usually with stickers pointing to them!) or you'll find it'll rattle itself to an internal death..
For quick visual reference, the later versions have silver clampers and the earlier versions black/grey.
Hope that helps!
Lee
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Sep 14 2013 4:37 PM
And don't forget the active FM antenna to make the Century complete. You need the wall bracket or table stand as well.
The sound of the Century is amazing!
Brengen & Ophalen
Razlaw
Posts 4,345
Razlaw replied on Sat, Sep 14 2013 5:36 PM
My first B and O purchase and still one if my favorites.
h1npw
Posts 1,130
h1npw replied on Sat, Sep 14 2013 6:47 PM
Lee, Leslie, Razlaw,
Many thanks for your replies - You've sold me on one !
I'm downsizing house in a couple of weeks and am thinking of having on of these in the shower room. Will have to find a way of supplying ( and wiring into) the Century with a low voltage DC power supply to keep it safe. I'm sure Mr Jarman will be able to help me out!
Thanks again
Cheers
Nigel
h1npw
Posts 1,130
h1npw replied on Sun, Sep 15 2013 8:29 PM
Got one!
Bang-Olufson-Beo-Sound-Century
A fairly reasonable price, I think.
Cheers
Nigel
Amazone
Netherlands
Posts 187
Amazone replied on Sun, Sep 15 2013 8:38 PM
Don't think its's wise to put it in the shower, but congratulations!
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Sep 15 2013 8:40 PM
It is Nigel, congratulations! Wall bracket and active antenna as well. New cloths on it and maybe another color and voila Smile
Brengen & Ophalen
Steffen
Denmark
Posts 1,408
Steffen replied on Sun, Sep 15 2013 10:51 PM
h1npw:
Thanks again
Cheers
Nigel
Unless you're having a very small bathroom - or you are planning to place it close to the showerhead, there's no need for that...
You can use the ordinary power outlet. Don't you have power outlets in your bathroom?
Here in Denmark most people have power outlets in their bathrooms.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Sep 15 2013 11:03 PM
Be aware, there are strict regulations regarding 230Vac use in a bathroom. Bathroom areas are defined in zones. Please Google and you will find enough information.
Brengen & Ophalen
h1npw
Posts 1,130
h1npw replied on Mon, Sep 16 2013 8:59 AM
Yes, definitely new cloths - SWMBO will choose the colour!
Re location - it'll be going in the shower room - not the shower! This site safety-in-the bathroom says that sockets should be 3mtrs away from the shower - the century probably will be about that distance from the shower, but I still want to have it wired into a low voltage DC feed rather than 240V.
Cheers
Nigel
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Sep 16 2013 9:15 AM
Safety first! Why not using a Beolab 2000? For that you need a masterlink but because of damps and humidity in your bathroom I don't think the Century would like that.
Brengen & Ophalen
h1npw
Posts 1,130
h1npw replied on Mon, Sep 16 2013 10:51 AM
Thanks for that suggestion Leslie - I do own a Beolab 2000 that I've never used! However, I'm totally unfamiliar with how masterlink works....
I will have a Beomaster 5500 and a CD50 in the bedroom. (this could be changed to a Beomaster 6500 and a Beogram CD6500)  So, several questions....
Is it simply a case of running a master link cable from the bedroom to the bathroom?
No power leads required for the beolab?
Will I be able to control the beolab's volume with a beolink 1000 in the bathroom? Or does it need a sensor to be connected to it?
Will I be able to switch from radio to CD from the bathroom? Also, how do I control the volumes of the beolab and the speakers (CX100) in the bedroom independently (Is it possible to switch off the speakers in the bedroom whilst I have the beolab playing in the bathroom?
Any advice will be much appreciated!
Cheers
Nigel
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Sep 18 2013 11:49 PM
You can not connect the Beolab 2000 directly to older systems such as 5500 or 6500.
You'll need a Beolink Converter box to connect them, as the BL 2000 uses Masterlink and there are no Masterlink sockets on the 5500/6500.
When connected correctly, you can control volume and switch between radio and CD from the bathroom -with your Beolink 1000 or directly on the Beolab.
h1npw
Posts 1,130
h1npw replied on Thu, Sep 19 2013 4:53 PM
Many thanks Steffen.
I think I will persue the Century option - I have to say I'm very impressed with the sound. As opposed to the active aerial - I will need to hook it up to an outside aerial. It's eventually going to be wall mounted so I will probably sell the handle and aerial - was very surprised to see they go for £45 on ebay which will bring my outlay down to about £110 which is pretty amazing. In the meantime I need a table stand which I don't seem to able to find on ebay or anywhere else.....
Cheers
Nigel
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Sep 19 2013 5:14 PM
h1npw:
Really? :-)
Brengen & Ophalen
h1npw
Posts 1,130
h1npw replied on Fri, Sep 20 2013 12:44 AM
Yes!  Can't find one anywhere!
Have you got one?
Cheers
Nigel
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Sep 20 2013 2:35 AM
I'd love to own a Century, keep my eyes open for one but have never seen one on this side of the pond for a good price that was in good shape.
A black one was used in Boomer's apartment on Caprica in the TV show Battlestar Galactica. Wall mounted.
Jeff
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Sep 20 2013 5:43 AM
Yes, I must have one some where. Maybe we can do a swap with your aerial? PM me and we can negotiate.
Brengen & Ophalen
h1npw
Posts 1,130
h1npw replied on Tue, Oct 15 2013 11:01 AM
Well, after having thoroughly enjoyed the Century in my office for about a month now, I've decided I need 2 more! I never cease to be impressed with the sound every time I switch it on. Need one for the kitchen and one for the shower room. One for the kitchen I need straight away, but the shower room one will wait until next year when we alter the room itself.
Can anyone tell me what the serial numbers / corresponding years are for the Century. I want to get a later one as possible.
Cheers
Nigel
Simonbeo
Posts 1,451
Simonbeo replied on Tue, Oct 15 2013 8:15 PM
I bought my Century in 1997 and I remember it was launched for £1000 to get people into the brand . Still got it on its wall bracket and still pleased with the sound . I think it was1150 with the bracket!
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Oct 15 2013 8:18 PM
The Century is a great sounding unit.  You'll be amazed how much better they sound on a wall though...
A very warm, analogue sound - which you can listen to for hours and hours.
I'm currently listening to vinyl on a lovely 1964 RG611 DeLuxe (quite rare actually!) in my study which has that same warm sound..
Lee
Danny Wells
England
Posts 67
Great piece of kit - I have two, one purchased new, one from e-bay. Totally trouble-free after many years of use, altho' I replaced the glass door in the e-bay unit as it was chipped. I still play compact cassettes ! so the Century is perfect.
They respond to the BeO4 remote and the volume can be controlled from a BeoCom 6000.
I agree with Leslie - make sure you get the FM antenna and the wall-mounting kit for best results - you won't be disappointed.
Mark
London
Posts 1,063
Mark replied on Wed, Oct 16 2013 1:50 PM
I need to stop reading these posts as this has now become another "want".
Any suggestions how I can get another system behind the wife would be greatly appreciated
h1npw
Posts 1,130
h1npw replied on Wed, Oct 16 2013 2:17 PM
LOL Mark!
I honestly think these are the best value for money B&O you can buy. I sold my Beolit 600 for £300 a few months ago which compared to £150 for a Century is barking!
Get it in the right colour and show the Mrs the sound and you won't have a problem!
Anyway,  can anyone help me with my serial number question????????????
MediaBobNY
Greenwich Village, NYC
Posts 1,106
The ones with brushed aluminum CD clampers are more recent than those with black plastic clampers.   For all B&O products:
 1****** - 1984
 2****** - 1985
 3****** - 1986
04****** - 1987
05****** - 1988
06****** - 1989
07****** - 1990
08****** - 1991
09****** - 1992/1993
10****** - 1994/1995
11****** - 1996
12****** - 1997
13****** - 1998/1999
14****** - 2000
15****** - 2001
16****** - 2002
17****** - 2003/2004
18****** - 2005
19****** - 2006
20****** - 2007
21****** - 2008/2009
22****** - 2010
Steph
France
Posts 1,059
Steph replied on Wed, Oct 16 2013 3:01 PM
I like the look and feel of the Century, very B&O.
I'm ready to buy one for the kitchen but...
It was replaced by the BeoSound 1.
Do you think the sound of the Century is the same than the BS 1 ?
I still hesitate...
h1npw
Posts 1,130
h1npw replied on Wed, Oct 16 2013 5:10 PM
MediaBobNY - Thank you very much! Never seen that info before - very useful.
Cheers
Nigel
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Wed, Oct 16 2013 6:22 PM
Steph:
I still hesitate...
The Century is much better imho!!!
Jonnie
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Oct 16 2013 10:42 PM
h1npw:
What do you mean?Whistle
Brengen & Ophalen
Mark
London
Posts 1,063
Mark replied on Thu, Oct 17 2013 9:27 PM
Right I've just bought a Century and it was not even on my radar.
Next time someone posts a good thread can they please post a warning 1st.
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Oct 17 2013 9:37 PM
supercarrambler:
Next time someone posts a good thread can they please post a warning 1st. We tend to forget there is more to design than designing.
So did I.😄😄😄😄
//Bo.
A long list...
h1npw
Posts 1,130
h1npw replied on Fri, Oct 18 2013 12:31 AM
Mark & BO - let us know what you think!
Cheers
Nigel
Mark
London
Posts 1,063
Mark replied on Fri, Oct 18 2013 9:55 AM
Ok this is not my picture but I do like this set up
h1npw
Posts 1,130
h1npw replied on Fri, Oct 18 2013 11:52 AM
When I first saw your post I thought "Blimey, this guy doesn't hang about!" Big Smile
Agreed - it does look good - no wires is a must in my book! Not sure about the light though.
Cheers
Nigel
h1npw
Posts 1,130
h1npw replied on Mon, Oct 21 2013 12:26 PM
ebay-CENTURY
Second one purchased! Smile  Later model complete with aerial, wall bracket and Beo4 all for less than £200!
This one will go in the kitchen -will post photos once installed.
One more to go!
Cheers
Nigel
kokomo
Spain
Posts 206
kokomo replied on Mon, Oct 21 2013 1:07 PM
Leslie:
Not here in Spain! First shock (no pun intended) when moving here was to see mains switches and sockets on the bathroom wall!
Page 1 of 1 (37 items) | RSS
