BEO4 (with nub) can be set to less IR strength? How to do that?
This post has 3 Replies | 0 Followers
georgey007
Posts 74
georgey007 Posted: Thu, Sep 19 2013 6:44 AM
Hi I read thet the new BEO4 (with nub) can be set to less IR strength? How to do that?
I have a open living room and dinning room and from time to time the 2 are interfering with each other.
Setting to Link is no option because I also have a Beolink active in the dinning room which is on link.
regards
hfat
Vienna, Austria
Posts 663
hfat replied on Thu, Sep 19 2013 9:01 AM
Found on archived forum:
Access the service menu by pressing stby + LIST at the same time, and then MENU + (joystick) at the same time. Press ^ several times until the display reads IRPWR: X. Again, 1 is the lowest and 7 is the max IR signal strength (default is 4)
hfat
georgey007
Posts 74
Thank you
manitou
germany
Posts 61
manitou replied on Fri, Sep 20 2013 9:33 AM
it is list instead of up.
but wherefore are the other items: a-d, cont ?
grüße
Page 1 of 1 (4 items) | RSS
