Could not answer, OK, tried to post an abuse report, but got this
You can reply if you are a moderator.
Peter
That is correct Peter.
Also the "Not Found" message is because it really was not found because Martin had deleted it just before you tried to reply.
Regards
I did not delete it.
Dillen: I did not delete it. Martin
Tried to report abuse on Martins "I did not delete it", same
