Beosound 5 Encore Wi fi connection issue
This post has 12 Replies | 2 Followers
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Tue, Sep 24 2013 8:51 PM
I recently installed an epsom wi fi printer, on installing it I made a change on my router security. When switching on the BOS5E obviously it would not connect. Now however when I use it to search for the wi fi it doesnt pick it up. So I have entered the router id and the passwords and it searches for it but still does not pick it up for connection. Anyone have any idea how I can solve this.
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Paul cheacker
Spain
Posts 130
Does anyone at all have any ideas please, I am getting BS5E withdrawal symptoms being without it now for 2 days.
scottyltd
Posts 19
scottyltd replied on Sat, Sep 28 2013 12:04 PM
Hello there,
Seems as this is a simple case of either router settings which have changed or IP address. Either the printer has turned off UPNP or the printer has the same IP as BS5E. If UPNP is off turn it back on in router settings. If IP address issue change BS5E ip address.
If you are not sure how to change these settings, just contact local dealer with these 2 suggestions.
kokomo
Spain
Posts 206
kokomo replied on Sat, Sep 28 2013 1:17 PM
Disclaimer first, I know nothing out the Beosound 5. However, have you tried switching off  the printer completely? Does the beo5 now connect to wifi? If not try re-booting the router. Then if no luck go into wireless router settings and switch to no security encryption, then see if BeoSound connects. If it does, at least you've then narrowed it down to your router's security settings.
Have you changed router settings to a type of encryption that the Beosound does not recognise - eg WEP, WAP, WPA etc?
Have you ensured the router's and Beosound wifi settings are exactly the same?
Apologies if this reply is a bit simplistic.
Finally, why did you change your security settings in the first place? Was this necessary to 'connect' the printer?
Millemissen
Flensborg, Denmark
Posts 14,680
Hi applemac,
I made a change on my router security "
Could you be more specific - what did you change?
Be sure that DLNA is enabled in the router settings, and that the (DLNA)server on the network is running.
N.B. Two devices with the same ip-adress on the same network is not possible.
Seems to me to be a port-issue.
Do you have a person with network-skills in your neighborhood?
Paul cheacker
Spain
Posts 130
Hi I made a mistake and change the security setting to connect the printer when I did not need to, however following your advice and switching of the security of the router allowed the BSE5 to connect to the router viua wi fi. However I cant leave the wi fi on without security.
Paul cheacker
Spain
Posts 130
Koko,
thanks you advice actually solved my problem, firstly I turn off the security on my router this allowed the BOS5E to connect to the router, after it obtainned a IP address etc I then switched the security setting back on my router. Turned off the BOS5E and turned it back on and it still connects.
Thanks for all the help
addi987
Posts 2
addi987 replied on Thu, Oct 11 2018 3:31 AM
Actually, the same issue I have also faced with my canon printer that time canon support helped me a lot to resolve the issue and also advice some very essential things regarding wi-fi printer which is important to know to make your printer long lasting.
Hussain Deewan
Dubai Aid city
Posts 1
Want an awesome looking jaw-dropping website? UAE Website development provides professional web development service in Dubai and provides 24x7 support with full customer satisfaction.
sumitbis919
Posts 1
If you have any inquiry regarding canon printer error 5b00, any of the specific issues you can contact us. To fix this error quickly make a call at our toll-free no. +1-800-824-4518. you can call or email at your convenient time, and the technicians will help you out instantly. Mailbox your queries to the mailing address and let the expert team help you.
Aussie Michael
Melbourne, AU
Posts 3,730
On the encore did you press right > twice and go and then find the network again ?
Perhaps forget the network and re add it
tony9909
Posts 1
tony9909 replied on Mon, May 20 2019 11:05 AM
Great answer. We provide professional Auditing services in Dubai at very affordable price.
Evgeny
Moscow
Posts 22
Evgeny replied on Tue, May 21 2019 9:05 AM
Some time ago I had a similar problem. Solved it as follows.
According to operation manual, you're network router should work in a 5 Ghz 802.11 standard. Please, check it in the router menu. It does not work in 2.4 Ghz range.
As addition - it is possible to connect Beosound 5 at the same time using Cat5 RG-45 cable and on Wi-Fi, helps too.
Authentification must be WPS.
Have a good day!
Page 1 of 1 (13 items) | RSS
