I have a BeoCenter 8000 and today the tape mechanism appears to have failed. I was playing a cassette, tried to fast forward and nothing happened. Now I can't play the cassette, fast forward or rewind and worse still I can't remove the cassette from the deck! Does this problem sound familiar to anyone? Is there a quick fix solution or am I looking at a repair job?
Welcome to Beoworld !
Your deck needs new belts.They all do by now.
Don't force anything.
Thanks Martin,
Is this something I can do myself or is it best left to the professionals? Is there a way I can get the tape out?
Cheers,
James
These autoreverse decks are a bit tricky.To get the tapeheads to disengage, you will have to take out the tapedeck fromthe Beocenter, flip it over and rotate the two flywheels. They rotate in opposite directions.Rotate by hand until the heads disengage. If the belt is slipping A LOT or has snapped, you may have tohelp both flywheels rotate.
Never force anything. If it doesn't "feel right", you are rotating the wrong way.
Two different tapedeck versions were used in production.I can supply belts for both versions and with mounting instructions (photos and english text).On a scale from 1-10 with ten being the most challenging, one version is at a five and the other at a good eight(!).
