CanI use MMC5 on a Beocenter 7700 ?
This post has 5 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Mon, Sep 30 2013 8:28 PM
Hello.
I have a Beocenter 2200 with a MMC5 and  a Beocenter 7700 with a MMC2
Is it possible to use the MMC5 on the 7700?
the condition of the MMC5 is way better and my 7700 is my preferable.
 If yes ? how do I remove the pickup?, just to pull it out ?
Sweden
My re-capped M75 are my precious diamonds.
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Sep 30 2013 8:33 PM
Yes, they are fully interchangable. Just pull it out to remove.
//Bo.
A long list...
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Sep 30 2013 8:36 PM
Yes you can, they are fully interchangeable.
To remove, you just pull it out. Very carefully of course. It may be a bit tight if it has been sitting there for 20+ years untouched.
--mika
MediaBobNY
Greenwich Village, NYC
Posts 1,106
And remember to change the tracking force and antiskating setting (if it's possible to).   And hold the tone arm stationary with your other hand when pulling out the cartridge.    btw, an MMC-2 is far superior to a bottom-of-the-line MMC-5.  But it sounds as if your MMC2 suffers from cantilever suspension degradation, a common problem.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Sep 30 2013 9:21 PM
Axel can make the MMC5 into a MMC2 - or could repair the MMC2.
Peter
Stockholm
Posts 512
Thanks, so much for good answers. I wll get back to this later and ask more questions about the pickups.
Now I need topost some other post as I am in service mode
What a wonderful forum I have found :)
Page 1 of 1 (6 items) | RSS
