Trouble of lifting the record player into service mode on Beocenter 7700 + no radio receving
This post has 3 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Mon, Sep 30 2013 10:05 PM
I have just bought a used Beocenter for some 35 equal euros,and find joy in reparing it.
The FM radio wont find any station,  well, the stereo light barely blink some where here and there and I can here fraction of receiving. Basicly the same syndrom if a radio dont have an antenna connected.
But antenna, I do have connected.
So my error tracking is to follow the antenna cable inside of the machine and check its antenna connection on several places.
The radio board seems to be under the recordplayer.
So, I have the correct type manual. and one  of the D screw  was not where it should due to manual , I had to guess.
The record player section seem to be stuck and I am unconfortable of putting any force into the manouver of lifting it
The control section went fine, very smottly
Anyone that have tips for me?
Sweden
My re-capped M75 are my precious diamonds.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 30 2013 10:19 PM
Two screws at the vertical backside.
One screw at the right outside of the turntable section, near the cassettedeck eject arm.
One screw under the platter, 7-10 cm from the front.
Then lift up the turntable section just like you did the operating section.
Stockholm
Posts 512
Thanks Martin,that was unbelivable easy, Mange mange tak Martin, det var super simpelt
Stockholm
Posts 512
So, now to post next thread. about the radio receving,  I have got my answer regarding getting record player into service mode
Page 1 of 1 (4 items) | RSS
