Beomaster 3000-2 connecting to Apple TV?
This post has 11 Replies | 1 Follower
robertscottcostello
Posts 7
robertscottcostello Posted: Sat, Apr 7 2012 10:15 PM
Is it possible to connect my Apple TV to my Beogram 3000-2? The Apple uses an optical audio output, not sure if there is anyway to interface this with analog.  Thanks in advance for the consideration.
Medogsfat
Leeds West Yorkshire
Posts 3,896
Do you mean a Beomaster 3000-2 amplifier? Beograms are record decks.
Chris.
robertscottcostello
Posts 7
I'm sorry, senility must be setting in. Yes, I meant Beomaster 3000-2 amp.
Evan
USA
Posts 3,621
Evan replied on Mon, Apr 9 2012 3:34 AM
Looks like certain Apple TV's are easier than others.. Some have analog audio and others don't.
Since you have brought up the question and are having difficulty, I am going to assume it only has an optical out. Which means you need to get an optical -> analog converter.
Good luck!
Beo4 'til I die!
robertscottcostello
Posts 7
Exactly.  I'm assuming the conversion from optical to analog is improbable.
pacificocean
Posts 100
search for a DAC
robertscottcostello
Posts 7
Thanks pacificocean. I'm astounded that the solution is so simple.  I was assuming any conversion would not be separate from an amp. Glad to be wrong.  I see several options out there for DACs, mostly affordable.
Evan
USA
Posts 3,621
Evan replied on Mon, Apr 9 2012 1:45 PM
robertscottcostello:
No, not at all.
http://www.amazon.com/HDE-Digital-Analog-Audio-Converter/dp/B0040TQOMK
Beo4 'til I die!
robertscottcostello
Posts 7
Thanks Evan! I saw this one, too.  Also an option to aquire the cables for a modest fee.
pacificocean
Posts 100
Keep in mind that there is a hugh quality difference in dacs. Mostly you get value for the money you pay. I payed more for my dac then for my second hand beomaster.
robertscottcostello
Posts 7
Wow, you aren't kidding about the price differences.  I may have to go the lesser route for the time being.
robertscottcostello
Posts 7
I'm going to see what happens when I edit the title to make it more correct.  My apologies if I screw up this thread.
Page 1 of 1 (12 items) | RSS
