1. Is there a double Masterlink wall box?
I'm going to install two Masterlink devices close to each other. I've already covered the wall with too many single-gang connector faceplates, so I'm looking for ways to reduce the space used. I've already got some "Masterlink + 75 ohm aerial" faceplates, but realy need a "Masterlink + Masterlink".
2. Where can I get surface-mount back-boxes for Masterlink faceplates?
I've currently got square "Masterlink + 75 ohm aerial" faceplates on the front of UK plastic surface mount pattress boxes. However, these round-cornered faceplates do not really fit UK boxes properly.
3. Where can I get recessed-mount back-boxes for Masterlink faceplates?
In the longer term, I'd like to sink the back-boxes into the wall, so that the faceplates end up flush with the wall surface.
4. Are back boxes available for the slim-look Masterlink faceplates?
I like the look of the slim-look faceplates, but they look even less like UK shapes. Are metal or plastic back boxes available for these, over here?
Mark
Hi there
i think your best bet would be to contact Steve at http://www.soundsheavenly.co.uk/bando.htm
he has all sorts of stuff like that
cheers
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thank you for the suggestion. Now in discussions...
