Beogram 6002/8002 cable
This post has 7 Replies | 2 Followers
the_o_master
Posts 856
the_o_master Posted: Mon, Oct 7 2013 1:30 PM
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
I am looking for the cable for two of my B&O turntables. I own Beogram 6002 and Beogram 8002, both with DIN socket on the rear panel and I want to use them with diferent Beomasters which I also own. So I would have cable for these Beograms, with 7 pin / pole DIN male Plug / Connector on both sides of cable. I need this to have a possibility to start the turntable with remote control when used for example with BM6000. I know that on the original B&O cable it was possible to screw 2 of 7 pins out to use these turntables also with older Beomasters (or non B&O receivers). Is it any chance that somebody has this original cable for sale? If not, I would be glad if somebody could post the picture how the pins should be wired. I presume it is the same as “B&O” 5 pole DIN plug but with pin nr.6 for a data transmission (ON/OFF turntable). Am I right?
 Theomaster
Vintage Bang & Olufsen
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 7 2013 4:08 PM
The simple answer is, ask Steve who advertises here (see bottom of this page). He's got everything you need - and his prices are very buyer-friendly!
It is also possible to make them yourself, the 7-pin DIN plugs being readily available, along with suitable braided cable. Well, if you like that sort of thing, that is.
Jacques
the_o_master
Posts 856
chartz:
Hi chartz,
thank you for your post. Yes, probably it would be the easiest way to order the cable from Steve. I wiull contact him.
But anyhow I would be glad to see how the pins are connected on the 7 pin DIN cable Unsure
the_o_master
Posts 856
Not looking anymore.
Of course it was the easiest way to call B&O locally Indifferent
They have these cables still. I ordered 2 Pieces: EUR 15,40 / Piece ...
Orava
Finland
Posts 991
Orava replied on Thu, Oct 10 2013 2:34 PM
Double shielded?
the_o_master
Posts 856
Yes I think.
I ordered them and I was told they are original cables for BG6002/8002.
Today my wife will collect them and I can tell you if they are.
BR
Orava
Finland
Posts 991
Orava replied on Thu, Oct 10 2013 6:01 PM
While exploring info for my 8000 I just learned about PH marking(double shield) on cable. I have one and did not know it is especially for these. Have to find new for my CD5500.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 10 2013 9:31 PM
I made one, very easy. I used old stock Neumann microphone cable and Neutrik 7-pin DIN plugs.
Jacques
Page 1 of 1 (8 items) | RSS
