I was wondering if anyone know how to take off the front gril on Beolab 8000, one of my speakers stop working, no standby light and no sound, I tried diffrent plug in the house as well as diffrent power cord. One of the members suggested that I check the fuse 1, 2, but to get to that I have to remove the front gril to get to the fusesThanks,
Alan
They are a tight fit and can be hard on the fingers.
Thank You so Much, this helped alot
Regards,
Problem was not the fuses, I think it is the stanby transformer that gone bad, I was wondering were I could puchse one?
Thanks,
Thank you so much, it helped me a lot, but I found out it was not the fuse, it looks like my Standby Transformer gone bad, now I have to look for a standby transformer, any suggestion where I might be able to find one? I would apprecite any help I can get
It would help if you informed us as to your location! You can do this in your profile or just put the information in your posts.
I have answered your email thus:
Try Atlantic Systems Electronics 24 Rockland St Hanover, MA 02339, United States+1 781-826-8760
They have been known to supply spares in the past.
Regards Graham
California, USA,
California, USA, Thanks for bringing it to my attention. I went and updated the profile to reflect my location
