Does anyone else have a BS4 that they've brought with them to the US? If so, what do you do to get FM?
Also on the US version is the radio antenna input different?
I have brought back a BS2300 many years back and that worked fine.
I think on very old radios there can be an issue with the steps between frequencies, but have never had an issue and doubt that BS4 has that
The Antenna plugs in US arebe different, but really, not many peeps use external antennas.
I would recommend bringing a plug. Radioshack sold EUR to US converter at reasonable cost for power
Cheers
JK
Heya sorry. I meant from the antenna standpoint. I can get a couple of strong channels but they're sort of fuzzy.
