Config Tool crashes when downloading configuration
This post has 3 Replies | 2 Followers
hfat
Vienna, Austria
Posts 663
hfat Posted: Sat, Oct 12 2013 11:33 AM
Hello,
Today I encountered a problem with the config tool. When I download a configuration to the Beo6, the tool serializes the configuration. Just when the download screen appears it crashes. I reproduced the problem with Win7 32-bit running config tool 6.00.02.
Any ideas?
hfat
Griebel
Posts 416
Griebel replied on Sat, Oct 12 2013 10:47 PM
The version of the Config Tool you're using is unstable. Suggest to install the latest update. I solved all my crash problems by installing the latest version.
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Oct 14 2013 11:06 AM
Thank You,
It's working now.
hfat
Chris Harrison
Peak District
Posts 381
Horst, have you got the latest version?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Page 1 of 1 (4 items) | RSS
